Hey guys I've been resetting my check engine light for quite awhile because its been throwing code P0442 for a small emissions leak.
It kicks semi regular so I just reset it and write it off to the locking gas cap I got as leaking around seal. This time when the check engine light came on I assumed the same and when I hooked up my OBD2 reader it has code P0137. Looked that up and it says its the O2 sensor Low Voltage Sensor 2. Anybody ever gotten that code? What do you suggest I do first to fix it? Thanks guys.
