Old 02-13-2011, 06:19 PM   #1
headgsket or intake gasket
I have a friend that has a 1999 grand am with 100,000 miles. They say that the car eats a lot of coolant and that the engine shakes real bad for about 10 minutes and then calms down. also it over heats in the summer and shuts down. The other problem they are having it that the fuel it cut when the tank is half full so they have to always keep the tank above halfway.
Old 02-13-2011, 07:02 PM   #2
Its killing its self
Old 02-13-2011, 07:32 PM   #3
major head gasket leak
no mention of lots of white smoke?
Old 02-13-2011, 07:33 PM   #4
ya there is white smoke i bet it is leaking internally because you can not see any coolant leaking.
Old 02-13-2011, 07:34 PM   #5
alero_bmxer
alero_bmxer's Avatar
I'd say head gaskets, thermostat and possibly fuel pump. sounds like they have driven it a lot overheating and such like that so i'd say it probably also warped the heads.
Old 02-13-2011, 07:40 PM   #6
well i know what i am doing tomorrow during engines class. I am going to send the heads to a machine shop.
Old 02-14-2011, 08:48 PM   #7
zzyzzx
zzyzzx's Avatar
