Old 02-26-2011, 10:20 PM   #1
cannaert
cannaert's Avatar
cannaert is an unknown quantity at this point
Send a message via AIM to cannaert
Motor Cranks but no Start.
Ok I just did a LIMG on a 02 Malibu.
Here the is whats going on.
The motor Cranks and Cranks then tries to fire but nothing. Spray some starter fluid in and She goes.
All the electronics are hooked up. Wires are in the right order, Coolant topped off, you name it and I have checked over and over and over again.
Fuel pump is work and is bring fuel up to the Rail. Only thing I think I can be is the pressure drops off when the motor Cranks.
Mind you the Car ran before I worked on it. Ran like s*** but it ran. Now It runs 100 times better but only on Started fluid.
I am getting pissed off at the damn thing and want to get it out of my Garage so I can fix my Own stuff now. I hate newer vehicles for this reason along.
I am going to have and take a little break from it.
DONT BUY A JEEP.
It will take over your Life.
cannaert is offline   Reply With Quote
Old 02-26-2011, 10:47 PM   #2
only 3 possibilities. no spark, no air, no fuel.
you have spark (starting fluid works)
air seems unlikely.
Theres fuel at the rail, but are your injectors spraying?
Old 02-26-2011, 11:27 PM   #3
cannaert
cannaert's Avatar
Just swapped out the injector harness and Same thing. I am wondering if the fuel filter is plugged or a line is plugged.
I am getting fuel to the rail b/c when I press valve in to release pressure I am getting fuel to come out but its not much and more of a dribble.
DONT BUY A JEEP.
Old 02-27-2011, 12:33 AM   #4
Are you sure you plugged in the 24x crank sensor?
Old 02-27-2011, 12:42 PM   #5
i am with cliff aswell
Old 02-27-2011, 03:02 PM   #6
Greencoupe2.2
Greencoupe2.2's Avatar
Greencoupe2.2 is on a distinguished road
maybe passlock? see if your security light is on
Greencoupe2.2 is offline   Reply With Quote
Old 02-27-2011, 03:40 PM   #7
XanderWiFi
XanderWiFi's Avatar
when you turn the key to "on" do you hear the fuel pump "burrr" on?
Old 02-28-2011, 10:08 AM   #8
doug
doug is on a distinguished road
try fuel pressure regulator
doug is offline   Reply With Quote
Old 03-03-2011, 01:58 PM   #9
cannaert
cannaert's Avatar
Well after messing and checking everything over the other day. Its the Fuel pump. Took a rubber hammer and beat on the the tank and it fires right up.
I was getting fuel pressure and it was reading ok on the gauge but when it would crank over it would not make enough pressure. But I got the car fixed and running. Buddy now has to spend 300 buck on a fuel pump.
DONT BUY A JEEP.
