08-16-2004, 03:01 PM
WAI / CAI quick set up and I painted the fuse cover red
08-16-2004, 03:03 PM
The filter is a K & N
The stock number is KNN-RU-2430 on Summit Racing It fits perfectly behind the battery and on the CAI tube as well
08-16-2004, 03:09 PM
Nice. I like that quick setup. Do you have a filter in the fender or do you swap one filter.
Mounted my Casper high speed fan switch
I had to move this relay on the fender, I busted the nut (literally) holding it on, luckly I had an extra bolt in my tool box. I grounded the switch to something else.
In the risk of busting another nut  I just tied the power to the bottom of the postive lead off the fuse box instead of unbolting the bolt that would not budge. I have a hex nut holding it on :thumbsup:
08-16-2004, 03:12 PM
I have another filter inside the fender, same as the WAI set up. I do have a different filter that I use for CAI. I only swap then to clean the filter. I don't like putting it back all wet and slimely
\/\/\/\/ See it's just hanging out :thumbsup:
08-16-2004, 03:14 PM
I also broke my 1/8 drill bit so I could only zip tie one relay, bolt one, and the other is under the pollution pump.
Since a broke the bit, I also could mount the switch and LED
08-16-2004, 03:15 PM
the switch
here for now
08-16-2004, 03:20 PM
Had to keep the wires away from the fan and the manifold. The pollution pump hoses are in the way of mounting it above the rad.
08-16-2004, 05:15 PM
ALEROMOD RAPIST
Just hope it doesn't all fall out on the track in 2 weeks. :P
08-16-2004, 05:41 PM
Yeah me too :unsure:
No it's in there pretty good
08-17-2004, 09:51 AM
I see you broke the ground on the passanger side lol I did the same thing yesterday
08-17-2004, 10:42 AM
Nice setup. How long does it take to switch between the two now as compared to before?
08-17-2004, 11:05 AM
looks nice...maybe i missed it but how long did it take
08-17-2004, 06:55 PM
if you use two different filters, it only takes about 5 minutes
That also depends if you have the clamps on the downpipe accessable without removing the battery.
08-17-2004, 11:43 PM
wowie, wish i had a high speed fan switch
AUTOBOT
