03-08-2011, 07:40 PM
tire width??
as of right now i have my winter wheels on (stock)
and those are
215/60/R15
i have summer wheels with tires on them that are
215/45/R17
would the tire size of 245/50/R17 fit onto the rims?
03-08-2011, 07:56 PM
245 is just too wide for the alero, you might get it to fit but it will prob rub when a full turn is needed
03-08-2011, 08:32 PM
 umm no......I run 255s, the problem with the tire size he listed is it is way too tall. You need some 235/45/17s
245 is a goofy size because it is either almost an inch tall or short, depending on wether you get a 45 or 40 series tire.....
03-08-2011, 09:47 PM
Originally Posted by kwhauck
 umm no......
i tend to just skip over his advice/knowledge sharing posts
03-08-2011, 10:32 PM
go to tirerack.com and compare sizes and get close to your size
03-08-2011, 10:37 PM
I had 245's on my Alero it it didn't rub anywhere.
On the subject of tire width, does anyone know if a 235/40/18 tire will safely mount on an 18 x 7" rim?
I'm a minitrucker-every build is a budget build
03-08-2011, 10:56 PM
yes...it will fit fine...
03-09-2011, 12:17 AM
AutoCross Alero
i run 235 40 17 front, 255 40 17 rear. but due to my rim offset i have to run a .75 spacer for the rim/tire combo to be flush with the fender, and i run -.5 camber in the rear for the race track so the spacer also keeps the tire off of the strut in hard corners.
03-09-2011, 08:09 AM
Thanks man
OP, sorry for the thread jack. I just didn't see the need to make a similar thread.
03-17-2011, 01:29 PM
Threadjacker!
Anyway, so i can get my hands on a PAIR of Pirelli tires for the rear that are a 255/45/17 and a PAIR of other tires (dont know brand name) for the fronts that are 245/45/17.
question is...
WILL THEY FIT ON THE RIMS I HAVE NOW?
THE RIMS HAVE TIRES ON THEM RIGHT NOW THAT ARE 215/45/17 ONLY THING DIFFERENT IS THE TIRE WIDTH.
I DONT CARE ABOUT IF IT RUBS JUST WANNA KNOW IF THE NEW TIRES WILL FIT ON THE RIMS
03-17-2011, 01:49 PM
I gave you the tool to find your answers. But if you insist:
The stock tires are 25.2" overall diameter.
The rear tires will be 26" overall diameter.
The front tires will be 25.7" overall diameter.
The width difference is minimal, as is the change in overall diameter. Your speedometer and final drive ratio will be off only slightly.
03-17-2011, 02:15 PM
so it blatant terms...they will fit?
03-17-2011, 02:39 PM
Theoretically, the 255s should fit in the rear fine, and the 245s shouldn't rub as long as you don't have a stupid high offset on your rims.
03-17-2011, 05:59 PM
I have 245s on my 18 X 7.5 rims and i have no rubbing
03-17-2011, 09:07 PM
And i have 255s on my 17x8 rims with no rubbing, but it is all about the offset....LIKE I PREVIOUSLY MENTIONED.......
03-17-2011, 10:05 PM
Let's Play Army!
Originally Posted by black
03-18-2011, 12:13 PM
Nippon Racing wheel Model Elegante,STW-012 offset 40 size
theres the details on the rim this is what they look like..only they are gunmetal gray (first pic is of the rims)
http://pumachaussures.net/wfs/mag%20...ppines .html#
03-18-2011, 01:14 PM
Let's Play Army!
+40 will work on our cars. +35 to +42 on normal rims will work. (obviously if you get something wacky like a 4 foot wide wheel, an offset that work s will be way different. lol)
03-18-2011, 01:44 PM
Owner
I have 255/40r18 all the way around. On the front they rub a little on the fender liner turned all the way. The OSV runs have a 42 offset. On the rear I have 1" slavery to clear coilover and proper OSV spacing.
Beware of the BackStabber
