Old 03-26-2011, 01:12 AM   #1
colonel6632
colonel6632's Avatar
6.5 in the door.
hey guys, i know this has been covered but i bought a nice new 4 channel amp. and my 5 1/4 speakers up front are blown and can't quite handle the power, so i was going to get a new set, but this amp would love some 6.5 components.
can i get an mdf 6.5 ring and put it in my door. i could try to dremel away some of the low parts of the door panel.
i remember cherrington mentioning someone actually putting 6.5s in the doors without fiber glass
Old 03-26-2011, 07:39 AM   #2
Jab did it. Check with him.
Old 03-26-2011, 05:44 PM   #3
colonel6632
thanks cherry, hopefully he find this thread
Old 03-26-2011, 05:50 PM   #4
jabartram
AutoCross Alero
jabartram's Avatar
i used the trim ring from the grill as a spacer with some low density foam as a filler. works very well to this day. what are looking for components wise? im looking to sell my focal 6.5s pictured with rainbow cal25 tweeters and custom tweeter pods where the factory tweeters go.
Old 03-27-2011, 03:02 PM   #5
colonel6632
so sexy
Old 03-27-2011, 05:32 PM   #6
kROntast1c
kROntast1c's Avatar
kROntast1c is on a distinguished road
gimme a while, but i will go outside and take pictures of my set up, just need to charge my camera first.
kROntast1c is offline   Reply With Quote
Old 03-27-2011, 06:49 PM   #7
Cashdollar2009
Cashdollar2009's Avatar
Are you just not feeling 5.25"s or?
Because you can find just as many 5.25"s that will handle the same power as the 6.5"s will.
I have only had experience stepping up from factory 4x6"s to the Fosgate Power Series 5.25" component system. I had to make an mdf spacer to get the motor and basket to fit through the cutout a bit.
Under construction...
Old 03-27-2011, 06:53 PM   #8
jabartram
AutoCross Alero
jabartram's Avatar
if you mount them to the back of the panel as i did you get a better angle, thats why i did it, i have adapters i just chose not to use them.
Old 03-27-2011, 08:28 PM   #9
^I followed his lead. It was a novel idea.
The big thing is making sure you rotate the speakers so the screws fall into area's that cant be seen. For example, on my panels the screws went into the grille mesh area- which is melted so its non removable. One went only into white plastic but didnt come out the face where you could see.
I chose to use clear silicone then to seal the speaker 100%. Worked AWESOME.
