Old 04-06-2011, 10:15 PM   #1
C.CLARK33
C.CLARK33's Avatar
C.CLARK33 is on a distinguished road
03 alero egr problems
service engine light keeps coming on a.a said it was the egr changed it 2 times still showin same problem any ideas?Engine also hesitates after 45mph when i give it the gas.
C.CLARK33 is offline   Reply With Quote
Old 04-06-2011, 11:38 PM   #2
i thought only the 99 yr had egr? wat did u change twice?
Old 04-06-2011, 11:52 PM   #3
99 was the only year that DIDN"T have it
Clogged cat?
Old 04-07-2011, 01:36 AM   #4
All the V6s have EGR regardless of the year.
What DTC is it?
Old 04-07-2011, 10:28 AM   #5
alerored04
alerored04's Avatar
Definitely the cat. I had the same issue.
My car breaks alot.
Old 04-07-2011, 03:53 PM   #6
C.CLARK33
C.CLARK33's Avatar
Thanks for the help will get the cat checked out.If it is the cat i will probably go ahead and get new pipes.
Old 04-07-2011, 09:01 PM   #7
C.CLARK33
C.CLARK33's Avatar
What DTC is it?
What does DTC mean?
Old 04-07-2011, 09:03 PM   #8
C.CLARK33
C.CLARK33's Avatar
Yea i replaced the plugs and wires and still does it i'll get the cat checked thanks for the reply.
Old 04-07-2011, 10:31 PM   #9
G.I.Ceo
G.I.Ceo's Avatar
G.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond repute
Not having a EGR wont cause the problems your having. I deleted mine and all I had to do was shut the light off for SES that it was giving me. I would get that CAT checked out. The DTC is a diagnostic code that is given when something fails. Our cars have pages of them for when stuff goes wrong.
G.I.Ceo is offline   Reply With Quote
Old 04-16-2011, 07:08 PM   #10
C.CLARK33
C.CLARK33's Avatar
Finally got the problem solved i had the cat changed then it showed up a misfire on #5-after the cat was put on still had the same problem used another dt to check it and it showed a misfire changed coil car runs good now anyways it was time for a good tune up thnks guys for the help.
