Go Back   Aleromod.com > General Help > Paint and Body Work
Old 04-26-2011, 07:22 PM   #1
Christato71
Christato71's Avatar
Christato71 is on a distinguished road
Send a message via ICQ to Christato71 Send a message via AIM to Christato71 Send a message via MSN to Christato71 Send a message via Skype™ to Christato71
Trunk Leak
What would be the best way to fix this leak? Epoxy? All suggestions welcome. (Sorry about the last picture being so blurry, you can still see where the water is entering at.)
Blog
Christato71 is offline   Reply With Quote
Old 04-26-2011, 10:18 PM   #2
the location of that picture would help, is that the trunk?
edit: oh word its in the title. you could try using some type of silicone or another type of sealant
Old 04-27-2011, 09:47 PM   #3
Christato71
So, just put a bead of silicone over the outside and inside of where its leaking?
Blog
Old 12-12-2011, 12:37 PM   #4
zzyzzx
zzyzzx's Avatar
I would also use caulk.
Old 12-13-2011, 05:45 AM   #5
Slab some silicone around there and you'll be good.
Old 12-13-2011, 08:40 PM   #6
unchained01
unchained01 is on a distinguished road
3m painatble seam sealer Just make sure to clean the area very well and you can use an acid brush to apply it
unchained01 is offline   Reply With Quote
Old 12-14-2011, 07:16 AM   #7
what we use at the dealer is stuff called Hightech by kent automotive. stuff comes clear and works great. reminds you a lot of thick supper glue. you could check your local auto parts or dealer parts department.
with what ever you get id make sure to clean the area with some degreaser or gental solvent and then pack it into the crack reall well. no such thing as too much. and then maybe do a layer in the inside.
Old 12-14-2011, 12:12 PM   #8
unchained01
X2 on the kent hitech. I have used it also it gets alittle harder than the seam sealer but does a good job.
