05-05-2011, 07:37 AM
struts
I have a 04. With 3400. I'm about to replace all 4 struts. I. Heard if u lower the car that gives it better handling. If I do I was just gonna cut the springs down. Is that recommended? If so. How much should I cut. I don't want the car too low. I live in ohio. Pot hole central. Thanks. Rocky
05-05-2011, 07:59 AM
Cutting springs will make your car handle like shit. Dont do it! I would recommend getting ebaich springs with some kyb struts
05-05-2011, 10:24 AM
Never cut springs, you have to use a cutting torch and when you heat up spring steel it becomes less spring and more holy-crap-stiff. If you want your car lower do it the right way, probably with the eibachs if you can find them cause it's only like 1.25 inches.
1987 Honda Rebel 450
05-05-2011, 11:54 AM
eibachs aren't made for our cars anymore.... H&R springs are good....or you can go the cheaper route.
05-05-2011, 01:05 PM
If you want better handling w/o springs... get STBs and upgraded Sway Bars.
05-05-2011, 01:12 PM
You ever see honduhs lowered but they cut there springs? You hit a small bump the car is like it has hydraulics.... just hops all over the place.. don't do it cheap... do it right so you have a good setup.
Originally Posted by Oldsnut
Originally Posted by tipnitty
05-06-2011, 07:33 PM
You been to tru lately sleepy?
05-06-2011, 08:07 PM
Yes!!! Goin tonight! Pming u lol
05-06-2011, 11:45 PM
My intrax spring really did improve my handling (especially my braking). The first time I braked after the intrax install, my tires all screeched. And no, cutting springs is not good. My cousin did that, and ended up flipping over in his truck.
