Old 05-08-2011, 06:41 PM   #1
robalero
headlights staying on.
alright so I just came home and my headlights are stuck on ( I pulled the fuses so it doesn't kill the battery ) but I pulled out my DRL fuse, pulled out both headlamp control fuses and the lights still stayed on.
as soon as I pulled my left and right headlight fuse they both turned off put them back in stayed on. flash my highs they stay on ( the lows ) anyone have a clue???
Old 05-08-2011, 07:11 PM   #2
Are they turned on instead of auto? The end of the turn signal selector rotates
Old 05-08-2011, 07:25 PM   #3
robalero
ive tried that, mine doesn't say auto on the bottom it says off but it really is auto
Old 05-08-2011, 07:28 PM   #4
jhubbz
⌘ Irish Pride
jhubbz's Avatar
have you tried physically disconnecting the light from the wiring? also are you running HIDs?
Done lost my mind
Old 05-08-2011, 07:36 PM   #5
C.CLARK33
C.CLARK33's Avatar
C.CLARK33 is on a distinguished road
try switching out the relay to see if the relay is goin bad
C.CLARK33 is offline   Reply With Quote
Old 05-08-2011, 07:41 PM   #6
robalero
yes im running HID's and no I didn't try disconnecting the bulbs but I figured pulling the fuse is the same thing. I am starting to think its a ground issue
Old 05-08-2011, 11:06 PM   #7
Is your ballast touching metal? Our headlights are switched on the ground.
Old 05-09-2011, 05:17 AM   #8
robalero
yes they are touching metal, thats something esle I read on another forum. but why would it just start doing it now? ill have to put something behind them like a rag or something see if it stops
Old 05-15-2011, 08:06 AM   #9
robalero
well yesterday I finally had a chance to look at my lights, so I put the fuses back in and now they are working perfectly.....what a wierd issue
Old 05-15-2011, 10:33 AM   #10
Ttop191
Ttop191's Avatar
i think cliff is onto something, it's probably not making a solid contact and therefore only doing it if the conditions are perfect
