Old 11-26-2003, 12:02 AM   #1
dopey
DIFFICULTY:
TIME:
u will need a grinder with a cutoff wheel or a hacksaw will work to.
go to ebay and buy urself an 98-02 HONDA ACCORD CAI setup. u can get these from anywhere to $40-$50 shipped.
u will get 2 tubes. one is shaped like an L..... this is ur top tube. u will need to trim 6 inches or so off this tube. just line it up and trim till u get the length right.
the second tube is shaped like an S. trim the bottom curve off that has the 2 connections for vaccum lines. again its about 6 inches or so. just trim till u get it to fit.
u will need to get 1 or 2 bigger couplers to fit the tube onto ur MAF. and if u want to replace the accordian connection between the MAF and Throttle Body that comes stock on ur car..... just use another coupler between those 2 and get grommets from autozone to plug the IAT sensor into.
and there u have it. an intake nearly identical and as nice lookin as similar CAIs out there.
u guys can thank me later
Old 11-26-2003, 12:21 AM   #2
99blackalero
havik beat you to this already but your way comes out cheaper if i didnt already buy one from u, which still sounds great and ive had no problems with
Old 11-26-2003, 12:51 AM   #3
dopey
like u said. this way is cheaper...... and looks better too.
Old 11-26-2003, 01:33 PM   #4
havik
The more threads we have on building CAI's the better, we learn more.
Good work Sweet :thumbsup:
Old 11-30-2003, 11:57 PM   #5
rabbitdaninja
Being a newbie and some what mechanically challenged is there any pics?
Old 12-26-2003, 01:46 AM   #6
rabbitdaninja
I appoligize for being such a newbie but I'm some what confused on what parts to buy ....maybe I've done too much research but I've found different descriptions of the CAI tubing and installation techiques. I was about to purchase this intake but seeing thread from here the tubing looked different and required cutting. Will this work http://www.n-body.net/tech/techdisplay.php?id=36
Old 12-27-2003, 07:06 PM   #7
dopey
if u buy the pipe in the link at nbody.net............ which is hte civic pipe. u have to cut ur inner fenderwell. most people dont want to do this.
if u buy the accord piping...... u dont have to cut ur car at all. just the pipe.
Old 12-28-2003, 04:53 PM   #8
rabbitdaninja
Ah ha !!! That makes sense. Thanks a lot.
