Old 05-27-2011, 07:39 PM   #1
knowledge8069
knowledge8069 is an unknown quantity at this point
Brand new engine, priming procedure for first startup?
Does anyone know what needs to be done to a remanufactured 2.4L engine before starting it for the first time? I am going to be installing one this week and would like to know what steps to take before starting it for the first time.
I understand the part about priming the system for oil pressure before starting it, but I haven't found how exactly this is accomplished on the 2.4L. Does anything need to be lubed manually before this step? Some articles I've read say to open the engine and pour oil certain places, other contradicting articles say there is grease already put on internal parts to lube them temporarily before the oil starts flowing.
The engine is complete already, pumps and all. Here's a link to it:
http://paceperformance.com/i-5135114...s-achieva.html
If anyone could give me a procedure, I would appreciate it. You guys have saved my ass more times than I can count! Thanks for any help offered!!
knowledge8069 is offline   Reply With Quote
Old 05-27-2011, 07:48 PM   #2
You pull the fuel pump relay, unplug the IDI cover harness.
Hit the starter and crank it for as long as you want.
Plug stuff back in, start it up.
[ion] C2 is online now   Reply With Quote
Old 05-28-2011, 10:23 AM   #3
widbyj
widbyj's Avatar
^Correct - I bought one of those a while back, no problems. As with any PROPERLY rebuilt engine it has 'assembly lube' on all of the wearing surfaces to protect it on initial startup. Mine even already had some oil in it and the filter in place, just as pictured.
Most important - BREAK IT IN PROPERLY for best life expectancy. There are many recommendations out there (google can be your friend), as I recall the engine came with no real directions. Basically just don't be harsh to it and vary RPMs/speed for the first half-hour or so, checking often for any possible leaks or problems. Then run the heck out of it to the 200 mile mark, about one tank of gas. Change to a good oil, preferably synthetic, and you are all set to go...
Old 05-28-2011, 10:41 AM   #4
knowledge8069
Will do exactly as you two said, thanks Ion and Wid!!
Old 05-28-2011, 12:00 PM   #5
Take it easy for 500 miles with varying RPM (NO HIGHWAY DRIVING), do oil change, 1000, oil change, 2000, oil change, 3000, oil change and you're back on schedule with normal oil changes.
Old 05-28-2011, 09:52 PM   #6
hok666
hok666 is an unknown quantity at this point
Why odd changing? because it is rebuilt?
hok666 is offline   Reply With Quote
Old 05-28-2011, 10:15 PM   #7
Yeah to clear out any metal shavings.. Engine has to break in.. extend the time taken between changes until you're at the usual 3,000 miles or whatever you like to do.
Old 06-07-2011, 06:25 PM   #8
knowledge8069
Ordered it today, the Alero will live again! Thank you for the help!
Old 06-08-2011, 07:41 PM   #9
knowledge8069
Sorry one more question. I've been reading about static and dynamic timing adjustment, mostly in the Goodwrench engine manual. Do I have to do any timing adjustments before or after starting the engine? Can't tell if this applies to us since it is in a manual with about 30 other GM engines. Thanks!
Old 06-08-2011, 07:42 PM   #10
no
Old 07-02-2011, 01:02 PM   #11
knowledge8069
The engine has been running perfectly for a few weeks now! The above instructions worked perfectly, thank you all for your help!
Old 07-02-2011, 01:36 PM   #12
Exactly what it says in the owner's manual
Never heard of this
But it makes sense after reading this
