06-11-2011, 02:25 AM
header priced at $110?
'00 Alero GL - 11X,XXX miles
-4500K/6000k/30000k(purple) HID's Hi/Lo/Fogs
-Carbon fiber pillars, door handles, and Gas cover
-Optima yellow top. This battery went end over end in my jeep (not strapped down) 13 times for 75 feet. and now is in my alero. one tough battery
-Cleared Corners/Painted Bezels
06-11-2011, 03:34 AM
nothing, its ebay lol.
Originally Posted by Oldsnut
Originally Posted by tipnitty
06-11-2011, 05:42 AM
So I get this and put it on I will get the same performance as I would from a pacesetter?
06-11-2011, 10:12 AM
Damn! Wonder if that would fit without modifications to my G6. That price is nice!
06-11-2011, 10:23 AM
Could be crap quality though
06-11-2011, 11:29 AM
it's fine
you'll have to use your stock gasket though to block the EGR tube hole
06-11-2011, 03:44 PM
so this will fit, give the same performance, with no modifications other than a new exhaust pipe? just want to clarify before I buy
06-11-2011, 08:13 PM
It'll work fine
06-11-2011, 08:41 PM
any tips on custom building the exhaust?
06-11-2011, 09:34 PM
sure. two tips on each side for a total of four would be great. but keep them under 3 inches in diameter please. take it to an exhaust shop. tell them you want 2.5" from the cat back, what type of muffler you want, and where you want the tail pipes to come out. if you want somone to build you a set of headers... good luck. and get a high flow cat.
06-11-2011, 09:53 PM
I just want the pipe bent, the tips/mufflers I will do myself. No catco
06-11-2011, 10:05 PM
just throw on the header, go to almost any exhaust shop tell em u want 2.5" piping and theyl do it usually around 200. if ur not running a cat tell em 2.5 back from the header and theyll do it, if theyre already doin the piping let em do the muffler while theyre at it. save ur self the work
06-11-2011, 10:14 PM
I'm a hell of a TIG welder SO i'll put the muffle on to save the cash. But I got no way to bend pipe. Thanks will go hit up the shops want sI get one in.
06-11-2011, 10:21 PM
if you want to go that route. take metal coat hook wires and straighten them. put like 10 together and "trace" your exhaust. take that into the shop, tell them to bend you 2.5" in that shape, and add a flange at the cat end. (use a gasket as a template for the flange)
06-11-2011, 10:30 PM
No cat needed but thats sounds like it shouldnt cost to much for me to do.
