07-18-2011, 10:40 PM
Rear Speakers stopped working! Help...
Hi all. Well I have owned my 2001 Alero for 1 week now, and have my first problem. Actually I noticed this the first day. The factory stereo system works fine but the rear speakers do not work. I tried the fader, I went into the trunk and made sure everything was hooked up. Tried wiggling the wires and harness but nothing. Then a couple nights ago I got in and started it up, the back speakers were working fine. I checked with the fader and yep! Course when I shut it off and turned it back on, no rear speakers. Any ideas? Please?
07-19-2011, 03:17 PM
Could be a loose connection on the back of the stereo. Sometimes this is just the way of older electronics, could be the stereo is failing or dust/junk in the fader controls. Note that a special harness adapter is required if you want to use an aftermarket head unit...
07-19-2011, 07:42 PM
Here is the factory stereo. The car is so clean I know there is no dirt, debris in the controls. Fader is electronic with just that little pop out button to adjust. Everything else on it works perfect.
07-19-2011, 10:20 PM
that doenst mean there isnt crap inside of it... or whose had it out before....
im willing to bet your having an issue with the radio. its the ONLY thing in common with both rear speakers. even if you have a factory amp you still have redundant wires going to the rear speakers (4 wires instead of two) and the speakers would still work if the amp didnt. id check the connection at the radio in back and if thats tight and all the wires are in the connector good (nothing looks pushed out) then id see about getting a nother radio cheap. i have one i can send you for cost of shipping but it would only tell you what your issue is... you would still need to find a nother radio cuz mines junk.
07-19-2011, 10:34 PM
⌘ Irish Pride
yea, your wiring could be decaying. i would just get a new headunit and call it a day. you will be much much happier with it in the long run
Done lost my mind
07-19-2011, 11:50 PM
...maybe you had the music too high...bass all the way up and blew both speakers.
07-20-2011, 01:07 AM
Ok... no question that it is a factory unit with no work ever done to it. I called the previous owner.
Next... Never had the volume up past about 1/3rd. (I'm an old guy). DID not blow anything up. (remember, I posted that I found this problem on the way home after I bought the car, the same day).
"your wiring could be decaying"... really? They do that? That would be a first in my 51 years of life on this planet. I'm just gonna go way out on a limb here and say... nope. They all look alive and well as I look at the underside of the dash...
Oh... I get it!!! Just get a new stereo! lol. Sorry... just playing a bit there. But you are right. Plus, a nice aftermarket system would be light years ahead of the plain jane that's in there now. Still, for now I'd just like to know what happened to my rear speakers...
07-20-2011, 07:04 AM
your radio has happned.
07-20-2011, 04:45 PM
Probably blown. Hook up a AA to them and see if they make noise.
Otherwise hook up a speaker to the wiring and see if it plays. Two super easy tests.. get to it.
07-20-2011, 05:59 PM
Is your rear defroster working? I know sounds nuts, but turn it on and physically put your hand on the back glass and see if it works. There is a module in the rear, at the roof line above the back glass on the passenger side of your car. May be toast...
2nd, any chance something in the trunk hit the little amp that is behind the carpet on the drivers inner quarter?
07-20-2011, 06:03 PM
what your talking about is the antenna module (and rear defroster) So.. his radio as a whole would go out, not just the rears.
its happened quite a few times on here. Especially since your not the first owner, take anything into consideration. (and people lie.. ALL THE TIME)
and not to sound like a prick (I know I will though)...
If your not going to take our trouble shooting advice into consideration, and not actually check things, then why bother posting about the problem? We can't just magically say "its this" and fix it for you, from our computers.
07-21-2011, 12:36 AM
I have checked out the things you all suggested, and I really appreciate your help! And even though you DID sound like a prick... LOL, just kiddin' man! I understand what you're saying. My thoughts were that maybe someone else had pretty much the same exact problem and figured out what the cause was. Please don't get me wrong, I really appreciate the help & suggestions. I know way more about the whole thing now because of you guys. I think you're right about it just being the head unit. They come on now and then, then the left one quits, then both work, then both quit. Weird eh? So gosh darn it! Guess I'll have to buy a new stereo! yeah!
07-21-2011, 07:06 AM
i have a stock radio out of a gls that will tell you if its the head unit. it doesnt have a screen but the radio still works. i just wnat to get rid of it.
07-21-2011, 11:01 AM
I actually found a used one that works for free. Just have to talk to Chevy garage for the security details, but thank you!
07-21-2011, 11:35 AM
If you checked, then you can ignore the whole thing I said. It sounded like you were blowing us off before you even troubleshot the problem.
Glad to hear you got a replacement. Keep us posted on if it works.
07-21-2011, 12:04 PM
shouldnt be any issues, i didnt have to do anything when i swapped mine. plug and play
