Old 11-26-2003, 12:26 PM   #1
3400SFI
My ABS and TRAC lights came on and now they won't turn off. Is this a common problem with our cars? If so whats the problem, and how do I fix it?
Anyone else having their brake rotors warp every few thousand miles also.
Old 11-26-2003, 12:45 PM   #2
3.4Alero
1. Are the trouble lights coupled with either a service vehicle or service engine light? If they are, let us know, we can help you from there. If not, try maybe checking the plug that is behind each of your rotors. That connects the wheel hub (wheel sensor) to the computer. Make sure it isn't loose.
2. OEM rotors suck. Replace them with Brembos or Bendix or some other aftermarket brand. Go to www.aleroupgrades.com for info on tthe Brembos, or go to www.advanceautoparts.com for the Bendix. I have the Bendix, and have been very happy with them. Folks with the Brembos will say the same.
Old 11-26-2003, 12:51 PM   #3
misslindseysue
^not much more I can say than that.
I've replaced one hub (other one is slowly getting worse), machined rotors front and back and replaced front rotors plus one caliper.
Old 11-26-2003, 04:16 PM   #4
3400SFI
The SES light is not one. Just the TRAC OFF and ANTILOCK lights. I'll check the plugs and see if they are loose.
I have Aftermarket crossdrilled rotors in the front that I bough t off of some ebay seller..
In the back I have stock rotors. So you think the Advance auto rotors in the back will do the trick? I think its my back rotors that are warped now, even though I just turned them in the spring. It really pisses me off actually.
Old 11-26-2003, 04:19 PM   #5
3400SFI
I just called advanced auto and they have rotors for $30 a piece by wear ever brand. Or Bendix on order for $79. a piece.
Old 11-26-2003, 05:42 PM   #6
3.4Alero
That's pretty expensive for the Bendix. But I never changed my rear rotors. I'm still stock in the back with 45,000 miles. And I race also. Guess I got lucky with those ones. Wear Ever should be fine for the back.
Old 11-26-2003, 10:09 PM   #7
brsexton
Wow...$79 is awful high for Bendix rotors. I didn't pay that much for my Brembo's.
2005 Honda CR-V AWD
Old 11-27-2003, 03:02 PM   #8
3.4Alero
Advance auto used to have three grades of Bendix rotors. I got the middle grade, for $48 / each. I think they stopped stocking them, though.
Old 11-28-2003, 11:57 AM   #9
3400SFI
Wierd the lights went off on their own.
Old 11-28-2003, 04:44 PM   #10
PapaBear101
Actually I'm have a similar issue with me car. This morning my TRAC OFF and Service Engine Soon light both came on together and now as I'm driving it shifts kinda hard.
Old 11-29-2003, 02:42 PM   #11
sound_xtreme
sound_xtreme's Avatar
i have the trac and abs problem. just those 2 lights come on and go off at times. its messed up.
Cardomain
Old 11-30-2003, 03:12 PM   #12
Insane75
*hmph* I've repalced 3..yes three forking front Calipers (four if you count the one that leaked right from day one and got brake fluid all over my rim :huh?: ) and the back ones need to be replaced. I have also replaced the pads 4 times and 4 new calipers. Oh ya....I've had the car a little over a year.
Old 12-01-2003, 10:49 AM   #13
PapaBear101
I got my ride fixed.... All it was, was a damn censor
Old 12-01-2003, 10:50 AM   #14
johny_boy32
johny_boy32's Avatar
^like i said&...the O2 Sensor
Old 01-12-2004, 03:06 PM   #15
Cyber Knight
Swank
Cyber Knight's Avatar
My TRAC light has come on randomly on 3 separate occasions. Only when I first start the car, and I have to turn the car off and start it again once or twice to clear it. Very strange, I guess I'm glad that I'm not alone on that one.
Old 01-12-2004, 05:45 PM   #16
nightrider
h same 2 lights come on for me too. the low trac light will come on a couple of times then the trac off and anti-lock light comes on i dint know if it was the cold weather (0-10 degree weather) was the cause but wut should i do to fix it.
Old 01-12-2004, 07:47 PM   #17
blueyezalero
My TRAC light used to come on all the time but not my ABS light. My SES light would come to and my Security light used to come on all the time. Now ever since I took my car in so the could fix my turn signal problem, everything is just fine now.
Old 01-15-2004, 07:00 PM   #18
3.4Alero
Figure out which hub is bad, and get it fixed.
