Old 07-25-2011, 02:27 PM   #1
Ingnition Cylinder Replace
i have another quick question about replacing my ignition cylinder and keyfob.
my keys were stolen and for some reason no locksmith around here wants to make me a new key. so im looking into just replacing the ignition cylinder. is there a relearn process after i swap out the cylinder? and is there a way to program a new key fob? also is there a way to delete a key fob? for instance im pretty sure the people who stole my keys are these junkies that moved on my block and my keys were stolen with the fob. is there a way to erase it so to speak so that old fob doesnt work? and make it so that only the new one does? i would take it to the stealership but i dont wanna drop a tone of coin. and i cant drive the car obviously without a key. im just looking for some clarification.
btw this is the new cylinder im looking at
http://cgi.ebay.com/ebaymotors/ACDel...Q5fAccessories
and has anybody changed out the cylinder before? anything i should look out for?
Old 07-25-2011, 02:39 PM   #2
I never replace the cyl myself, I had it done and the cyl was "rekeyed" for my keys.
That's not something you want I'm betting LOL but I'm pretty sure if you reprogram a new fob, the old one is deleted. At least that's the way it works with car alarms.
Keep in mind, that the door and trunk locks will match the old keys
Old 07-25-2011, 03:00 PM   #3
yea im have those rekeyed to match the new key. and im asking about the fib cuz i read somewhere that u can have up to 4 fobs on the same car. hoping cliff can chime in on this..
Old 07-25-2011, 08:47 PM   #4
foxsdaddy67
foxsdaddy67's Avatar
foxsdaddy67 is on a distinguished road
Send a message via Yahoo to foxsdaddy67
heres how to program your new fob.
http://www.programyourremote.com/cla...Ad.asp?id=1123
it sounds retarded but it works, i bought a used fob off of ebay and programmed it
foxsdaddy67 is offline   Reply With Quote
Old 07-29-2011, 01:29 AM   #5
Any GM dealer should be able to cut you a new key for a fraction of what the new cylinder would cost (especially if you're paying for installation)
Old 07-29-2011, 01:50 AM   #6
spc2125
spc2125's Avatar
i had a problem with my lock cylinder (it turned out to be something else) but i looked into it a lot and its wicked easy.
i called a junkyard and they say it only costs $10 for the part.
to get the part you just undo the radio bezel and the speedo bezel and unbolt a couple 7mm (IIRC) and bammo
http://www.aleromod.com/forums/showthread.php?t=29305
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
Old 07-29-2011, 02:28 PM   #7
well the new cylinder was only 75 and teh fact that some junkie has my original, i would feel better having a new key, and ive never payed the dealer to install anything, im going to do it myself... any ideas of the fob situation cliff?
a tip of the hat and some rep to you sir.
good find newb
Old 07-30-2011, 01:16 AM   #8
Well, once you program new fobs, the old ones will no longer work with your car. So just pick up some off ebay, etc... They can usually be had on the cheap.
Old 07-30-2011, 08:30 AM   #9
Install That Cyl Quick!!!
Old 07-30-2011, 12:12 PM   #10
spc2125
spc2125's Avatar
good find newb
Didnt want to be a rooster and say use the search button.
but gl with the car
just call me "Doc"
Check out my alero!
