Old 08-14-2011, 02:52 AM   #1
Question speaker in rear door?
ok so I just had what I think might be a good idea. would it be possible to mount a speaker in the rear door? where the light is in the pic, im thinking a 4" maybe a 5 1/4 will fit... but really, cut a hole, mount it to the door panel (with grill cover) run the wiring and it should be good right?
Old 08-14-2011, 07:09 AM   #2
robalero
a 6 1/2 would be best for sound quality but anything is doable as long as your willing to put the time and money into it
Old 08-14-2011, 08:21 AM   #3
foxsdaddy67
foxsdaddy67's Avatar
foxsdaddy67 is on a distinguished road
Send a message via Yahoo to foxsdaddy67
kinda makes ya wonder why they never put any in the rear doors anyway
foxsdaddy67 is offline   Reply With Quote
Old 08-14-2011, 08:59 AM   #4
robalero
easy, they had other models like the intrigue and aurora that had the speakers in the rear doors, hence if people wanted more they would have to upgrade to the other models of their cars.....marketing what can I tell ya
Old 08-14-2011, 12:51 PM   #5
Vella's Alero
Vella's Alero's Avatar
Vella's Alero is on a distinguished road
Also, Isn't that part partially covered by the seat?
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
Vella's Alero is offline   Reply With Quote
Old 08-14-2011, 01:43 PM   #6
robalero
I wouldn't have a clue I own a 2 door lol
Old 08-14-2011, 02:09 PM   #7
No. The seat fits in under there the panel stick out a whole bunch there. I'm really wanting to do it now, my biggest problem os going to be running wire though... I'm thinking if I do this I'll power theis via the regular speaker output from the head unit (the ones going to the rear) because everything else is amped.
Old 08-14-2011, 02:17 PM   #8
Why not move it forward then glass it in there? Learning to use fiberglass will be one of the most useful things you can learn to do...it will look a lot better and you can fit some bigger speakers too...
Old 08-17-2011, 06:33 AM   #9
foxsdaddy67
does intrigue rear door panels fit an alero? probably not that would be too easy
