Old 08-26-2004, 10:13 AM   #1
turtles_ride
okay now that i have the attention of all the preverts out there i have a question about my CAI. The one i bought has a little piece of metal tube about 1'2 inch long sticking off the side close to the MAF. I did a search and couldn't find any threads that mention anything about this little nipple, is a hose supposed to be attached to it, what's it for? Any help would be greatly appreciated. thanx
Old 08-26-2004, 10:19 AM   #2
alerosport.com
i did the civic intake one... and since it was made to fit a civic it has a lil metal tube you put some sensor in, but the alero doesn't have one i don't believe.
Old 08-26-2004, 10:41 AM   #3
coredump
My WAI had two things in the side, one was a hole with rubber gromet for the MAF, the other was the nipple you are referring to.
Heres a line from the instructions I got with my intake.
"Install the blue hose into the PCV hose by the throttle body. (just by pushing the blue hose into the PCV hose)"
Not sure which engine you have but I've got the 2.4.
The PCV bypass was rather easy to spot since it was the only black hose below and to the back of the TB that no longer had anything connected to it. When I get home I can take some pictures of it for you if you need them/want them.
Old 08-26-2004, 02:06 PM   #4
DCAleroGL
If u have the v6, the vacuum feed line plugs into the intake between the MAF and the throttle body. if you have 2 nips (like most of us haha) the first one is for that line and the second should be plugged. Use tape or silicone if you don't have a cap.
Old 08-26-2004, 03:42 PM   #5
turtles_ride
actually the cld air intake i got is one solid piece of metal. I'm pointing to the nipple i'm refering to, it came with a cap on it already. Any ideas what to hook up to it?
Old 08-26-2004, 04:00 PM   #6
jamcllw
It doesn't connect to anything. Leave the plug over it and you'll be alright.
Old 08-26-2004, 04:05 PM   #7
DCAleroGL
exactly, if you are not replacing the corrugated piece between the MAF and throttle body, it is extra. Leave it capped. Guess it is a universal tube?
Old 08-26-2004, 04:12 PM   #8
b-spot
b-spot is an unknown quantity at this point
thats not a CAI :rolleyes:
If I did went to college...
b-spot is offline   Reply With Quote
Old 08-27-2004, 10:02 AM   #9
DCAleroGL
In his defense, not many retailers refer to short ram intakes as WAIs, I shopped around and many called the WAI a CAI. We are the only ones that seem to really be picky about the difference.
Old 08-27-2004, 10:04 AM   #10
DCAleroGL
Besides, isn't it always a cold air intake in the frosty north? :P
Old 08-28-2004, 12:58 PM   #11
turtles_ride
why isn't it a cold air intake? the tube goes behind my battery and drops down into my wheel well like the others i've seen described as cold air intakes. I had to cut a small corner of the body out with a dremel for it to reach in there, but i get cold air from the front of my car. mmmmmmmmm i like talkin about nipples!!!
Old 08-28-2004, 01:40 PM   #12
j{}n
j{}n's Avatar
j{}n is an unknown quantity at this point
Send a message via AIM to j{}n Send a message via MSN to j{}n
sheesh... ok, one "nipple" is for the iat sensor, the other is for the little tube sitting behind the throttle body. if you're facing the engine, it comes "up" from behind the tb, and makes a right angle, then pointing "right". connect a hose from there to the metal "nipple"
'05 mazda 3
zoom zoom biatch
j{}n is offline   Reply With Quote
Old 08-28-2004, 10:07 PM   #13
You could get one of those little breather filters and clamp that on there.
I saw that in CrazyTaxi's car (I think it was his car :unsure: )
Old 08-29-2004, 12:07 AM   #14
-Alero-
-Alero-'s Avatar
that little nipple is for a line for nitrous, *a dry nitrous system* but yeah thats where your nitrous line runs to......
AUTOBOT
Old 08-29-2004, 10:18 PM   #15
test
test's Avatar
test is an unknown quantity at this point
it is a CAI if it goes down into your fender. That nipple thing is for the vaccuum tubes in civics and other applications. Just leave it capped, or plug it so it doesn't mess up the air intake flow.
HTML Code:
[img]http://www.aleromod.com/forums/image.php?u=1&dateline=1152636815[/img]
test is offline   Reply With Quote
Old 08-29-2004, 11:45 PM   #16
turtles_ride
Ya, its a cold air intake then because it does go down into my fender, it doesn't just stay under the hood in the engine compartment and suck in warmed engine air. And it only has the one nipple, which by the sounds of it, i should just leave capped. thanx guys. By the way i paid $79? for it on ebay i think, at the beginning of last summer.
Old 08-30-2004, 01:47 AM   #17
Sundayalero
Sundayalero is an unknown quantity at this point
Do you have any pictures of it installed?
<span style=\'font-size:8pt;line-height:100%\'>Every now and then when your life gets complicated and the weasels start closing in, the only real cure is to load up on heinous chemicals and then drive like a bastard from Hollywood to Las Vegas. Just roll the roof back and screw it on, grease the face with white tanning butter and move out with the music at top volume, and at least a pint of ether.
-From the book Fear and Loathing in Las Vegas by Hunter S. Thompson </span>
Sundayalero is offline   Reply With Quote
Old 08-30-2004, 11:06 AM   #18
turtles_ride
i haven't installed it again yet. I took it off at the end of last summer because i had to take my car to gm for a checkup and i didn't want my warranty voided, and winter was coming. But i will be putting it back on in the next couple weeks because i want to have it in for the niagara falls car meet. I'll take some pics for you guys when i get it back in.
Old 08-30-2004, 11:26 AM   #19
b-spot
Well in that case i'm a dink.
That is about the shortest CAI i've ever seen though, I'm thinkin that is gonna be a damn good intake because of the mix of cold air and short piping.
And DC, yes all of our cars here are fitted with FAI's or Frozen Air Intakes.
Old 08-30-2004, 01:44 PM   #20
DCAleroGL
like that one. The pic turtle put up sure looks like a WAI, didn't see the bend in it. {shrug}
