10-10-2011, 07:32 PM
brake light..
i was pulling into a driveway today to turn around and my brake light came on? my e-brake was all the way off and i just topped off the brake fluid a couple weeks ago due to a fluid leak (that was fixed) so what the hell could have caused it?
also, i've noticed people say the ABS and cruise don't work when the abs/svs/trac lights are on. but they all work for me when the lights are on. what the hell.
ALSO ALSO unrelated: are we supposed to have lighted footwells in the front? if so where are the light bulb locations so i can change them. (if nobody answers this i'll just make another thread about it haha)
10-10-2011, 07:50 PM
some have them and some dont
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
10-10-2011, 09:38 PM
I though mine were to then I relized it was just the center cousoul CUBBY* light hanging down lighting everything up. As for your brake deal, front hubs?
10-10-2011, 09:44 PM
will the brake light be caused by bad front hubs?
10-10-2011, 10:22 PM
My buddy's was, lit up e-brake, abs, service vehicle soon, and few other I think. A good way to tell is most of the time when they are going out they will whine/humm really loud
10-10-2011, 10:31 PM
mine doesn't hum, that's why i thinks its just a sensor. plus it happens when i turn the wheel hard, when it gets wet or when it's really humid out
10-10-2011, 10:34 PM
15.65 @ 87.3 MPH
I know you said the brake fluid leak was fixed, but when it came back on today did you check it just to make sure it wasnt low again?
10-10-2011, 10:42 PM
Hmmm, somethin is funky.
10-10-2011, 10:57 PM
Mine did this only it turned the ABS, Trac off and SVS lights on. It was caused by the wire that went to the wheel hub. It was slightly broken, not enough so that it was going off all of the time, but broken enough to where it would set off the lights when water got on the bare wire or i turned the wheel hard enough to pull on it.
10-10-2011, 11:49 PM
fuzzy, that's what i mean. the brake light is a different situation than the abs/trac off/svs lights (at least that i know of) i was just noting how it's weird that my abs and cruise still work when they're on.
and yes i checked the brake fluid level after the brake light came on. still topped off.
10-11-2011, 12:23 AM
Yeah I understood that, I just thought that maybe you could be having a similar situation only with one of the brake sensors? I'm not sure exactly how the whole system works but maybe there is a sensor wire for the brake that runs with same bundle of wires for the wheel hub?
As far as I recall there is only one bundle of wires that go to the front wheels...Like I said, I dont really know how the whole system works. I'm just trying to help
10-11-2011, 12:43 AM
i am thinking that your brake light is coming on from air in the brake system. although you had the leak fixed doesn't mean the brakes were bled properly which can cause the light to come on.
2000 Chevrolet Malibu LS
10-11-2011, 12:44 AM
Is it raining or did you just drive thru a puddle?
Mine comes on after going thru a big puddle
10-11-2011, 06:27 AM
sanity it wouldn't take 3 weeks for the light to come on if that was the issue. if your light is on its due to these things.
1 - low fluid
2 - sensor is broken and not reading properly
3 - broken wire going to sensor
10-11-2011, 07:47 AM
brake light came on again last night as i was pulling out of the driveway, then the abs/trac/svs came on 3 seconds later.... pulled back in to check brake fluid AGAIN (still topped up) and all the brake lines to make sure there was no leaks.
redog: the abs/trac/svs will come on if i drive through a deep puddle. thats kind of how i discovered the problem :P
im assuming this is an electrical/wiring problem then.
10-14-2011, 03:34 AM
great the brake light now comes on regularly along with the antilock/trac/svs lights
im scurred...
