Old 10-26-2011, 06:41 PM   #1
Hellfire5670
Hellfire5670's Avatar
Hellfire5670 is on a distinguished road
Exclamation Can i remove my security system?
My 2001 Alero has been a pain in the ass lately and it will not start, it cranks but wont fire up... leading up to the event when ever i tried starting my car a week before it happened it would start fine... then it would take a while to start.. i some times had to push on the pedal to start it. So what I'm thinking what it is, is the fuel pump i checked everyone of my fuses except the relays but im pretty sure its not my fuel pump relay..
I came along this site http://www.carcomplaints.com/Oldsmob...nt_start.shtml
Which from what i read it could be the security system... people said turn the car to "On" for 10 mins and the security light with stop
then turn it off and take key out for 10-20 seconds
then fire it up.. But i have a aftermarket head unit so i don't have the light..
Could i just take out the security system?
Has anyone had a problem like this?
i dont wanna spend 400.00 bucks for a new fuel pump and put it in..
Hellfire5670 is offline   Reply With Quote
Old 10-27-2011, 03:34 AM   #2
It's not the security system, if it was, the car wouldn't start at all.
Long cranks could be any number of things, including:
  • fuel filter
  • fuel pump
  • battery starting to go
  • alternator starting to go
  • bad relay (I doubt this one)
I know I'm forgetting something
As for the $400, find out what the problem is, and fix that probelm. The security system has nothing to do with your problem. You can still spend the money for a new pump, if you want to
Old 10-27-2011, 04:29 AM   #3
Hellfire5670
  • fuel filter
  • fuel pump
I really doubted the passlock was the problem just wanted to be sure im really sure its the fuel pump 2nd time it happened to this car.. might just get a aftermarket one.. know of any good ones?
Old 10-27-2011, 01:37 PM   #4
i had this problem i took out the stock security system both of my alero's that i have had have had the problem and put in an aftermarket one and have not had any problems since. taking out the stock security system was not easy you have to make sure you what u are doing. There is a how to on here somewere i think.
Old 10-27-2011, 02:41 PM   #5
Walbro
Old 11-01-2011, 03:52 AM   #6
bizzy07
bizzy07 is on a distinguished road
could be the fuel pressure regulator
bizzy07 is offline   Reply With Quote
Old 11-01-2011, 11:24 AM   #7
could really be a number of things. check the simple things first like your fuses.
Old 11-01-2011, 03:07 PM   #8
Hellfire5670
Pree sure its the fuel pump i cant hear it when i turn the car on :S pree sure its not the relay cause i got it started just took me pushing on the gas
