Starter Switch Replacement
Forgive me if there are already threads on this, but can anyone give me some advice on replacing the ignition switch? Car is a 2000 GL with the 2.4 engine. I used the Haynes manual instructions to get as far as removing the instrument bezel surround--first problem is I cannot disconnect the stupid clip holding the trip odometer reset button. How does that thing disengage, exactly? I was severely tempted to just cut the wires.
Assuming I get that thing out and remove the instrument cluster, which seems easy enough, reading ahead gives me problem number two. The book's illustration uses a Malibu dash, which has the ignition assembly behind the radio surround bezel. On the Alero, so far as I can tell, the two bolts that hold the ignition assembly in are behind a featureless expanse of dashboard, and removing the trim ring doesn't help. Please, tell me there's a way to get to this thing without taking out the whole dash? That would be way beyond my comfort zone. And might require me to get creative with a dremel and a cut-off wheel...
