Old 01-09-2012, 09:10 PM   #1
Brett
Brett is on a distinguished road
Misfire Problem
Hey all,
I know I'm new, and I didn't create an account to ask a question... but I've been drinking so here it is!
2.2L 5speed alero, misfires at low RPM.
if I leave it in neutral, and grab the throttle under the hood and dump it? Misfire.
going 20-30km around a corner in 2nd gear and just dump throttle and clutch? Misfire. I used to be able to squawk tires a this.
It's pissing me off so much. I hooked it up to a scanner after a particularly rude bout of misfiring, and the car threw no codes.
I've been told it's the ignition pack on top of the ecotec. Anyone confirm/better suggestion?
Brett is offline   Reply With Quote
Old 01-09-2012, 09:44 PM   #2
how are the spark plugs? What about the fuel filter? How many miles on it?
Old 01-09-2012, 11:02 PM   #3
spc2125
spc2125's Avatar
FINALLY!!
I am sorry this is happening to you but ive been waiting for this to happen to somebody else so that I could finally lend my ecotec knowledge.
I can say from what you have said that it is indeed the ignition module atop of the engine. This happened to me last year and one of the cylinders was misfiring and i brought it to a mechanic and it costed $280!!!!!!!!
But all you need to do is get a new ignition module and i think youll be all set.
Its so easy to replace. (its easier than replacing your spark plugs)
Good luck and I hope this is what was wrong so you can be back to squakin those tires
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
Old 01-09-2012, 11:08 PM   #4
TaurineMike
TaurineMike's Avatar
TaurineMike is on a distinguished road
Originally Posted by spc2125 View Post
FINALLY!!
I had the same problem and found out it was my plug wires. Replaced them and worked fine or at least that was what was wrong with mine.
Mods include: Hood scoop, Black pin stripping, cool air intake, sound system(6 1/2 front 6by9 back pioneer), 1200w amp with 12dp switch, big three upgrade.
Mods in the making: 65mm Throttle body, B&M Shift Kit, Spyder3 hood scoop, HP Tuner??, Pacesetter Header, Magnaflow High Flow cat, and Catback Exhaust System
Unfortunately there is no misplacement for displacement.
TaurineMike is offline   Reply With Quote
Old 01-10-2012, 06:43 AM   #5
FINALLY!!
it maybe easier to replace but without a scan tool to show live missfire data to acompany testing, plugs and wires (eco has wires?) would be cheaper and in theory when guessing like this should almost always be the first thing to check.
Old 01-10-2012, 08:00 AM   #6
Brett
Plugs and fuel filter have both been replaced in the last 6 months. She was giving me a hard time starting so I replaced those then.
it's 177k.
Old 01-10-2012, 09:08 AM   #7
id still recommend atleast checking them. a lot can happen in 6 months. esspecialy on a high millage motor.
Old 01-10-2012, 09:08 AM   #8
did you replace those boots that are sticking out of the bottom of this piece...they work as your spark plug wire
Old 01-10-2012, 10:18 AM   #9
Brett
Can I actually replace the boots separate from the unit or is it all one piece?
Old 01-10-2012, 10:21 AM   #10
the boots are replaced separate they are $6-7 a piece
Old 01-10-2012, 10:44 AM   #11
Brett
Sweet can I just pick those up from GM?
Old 01-10-2012, 11:10 AM   #12
you can probably get them there...i got mine from orielly's
