Old 01-22-2012, 07:59 AM   #1
turboalero
turboalero is on a distinguished road
Gasket Thickness: engine build
gonna build my engine looking at parts on turbotechracing looking at the head gasket right now. i want to build an engine to take anything so should i get a 0.30 or 0.80
turboalero is offline   Reply With Quote
Old 01-22-2012, 11:22 AM   #2
doesn't matter
what matters is the ARP head studs, proper surface finish, copper spray, and torque.
Old 01-22-2012, 11:49 AM   #3
turboalero
whats copper spray and how does it work
Old 01-22-2012, 11:51 AM   #4
G.I.Ceo
G.I.Ceo's Avatar
G.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond repute
If you have to ask that question then you are already in trouble.
2002 Grand Am GT Turbocharged
Garrett GT35 / Turbo Headers / 2.5" high flow DP / 60lb Injectors / Custom SLP Exhaust / Ported 3500 Heads / Ported 3500 UIM/LIM / 65mm TB / Turbonetics Evolution WG / Greddy Type-RS BOV / Casper Adjustable FPR / Casper High Speed Fan Switch / Speedbuilt F/R STB's / Next Level F/R Sway bars / Eibach Springs / Dual Gauge Pod with Aeroforce Gauges / Big Four Upgrade / HP Tuners and more!
"Living is doing everything you want to do and dying is everything else"
G.I.Ceo is offline   Reply With Quote
Old 01-22-2012, 12:38 PM   #5
unchained01
unchained01 is on a distinguished road
Yeah i think you need some more research. And gasket thickness has to do with what piston quench you want and what the motor is being built for.
The wrong thickness can actually valve to piston interference or too thick can actually cause less optimal compression and volumetric effiency
unchained01 is offline   Reply With Quote
Old 01-22-2012, 11:32 PM   #6
High comp turbo is where its at.. maximum quench! Just pray for no det.
