Old 02-12-2012, 11:21 AM   #1
turboalero
turboalero is on a distinguished road
transmission
is the 4e40 and 4t45 run off the same computor
turboalero is offline   Reply With Quote
Old 02-12-2012, 11:23 AM   #2
it's the 4T40E and 4T45E... it's all in the PCM dude, accessed through HPTuners
Old 02-12-2012, 10:58 PM   #3
the 40 and 45 are both the same tranny. IIRC
Old 02-22-2012, 10:12 PM   #4
turboalero
will it work on a straight swap. my trans is slipping need stronger trany
Old 02-22-2012, 11:14 PM   #5
doesnt the 45 have slightly different enternals?
Old 02-22-2012, 11:17 PM   #6
Another 4t40 tranny
If your doing all this work, get the HPTuners. Changing the FDR with HP takes all of 2 seconds
Old 02-22-2012, 11:24 PM   #7
If you are going to replace the tranny why not just swap in a 5 speed.
Old 02-23-2012, 10:51 AM   #8
because there is more work involved......
Old 02-23-2012, 12:30 PM   #9
to me it sounds like he doesnt do any of his own work. he comes here, posts a thread whenever there is a problem and he probably doesnt even use the search button but if he turbo'd his alero himself, i figured he would know alot of the questions hes already asked. not trying to be a d*** but...
Old 02-23-2012, 06:57 PM   #10
turboalero
I do, do my own work. ld9 is a new block to me I have built Honda and integras before and I just built a srt4 in by boys backyard that made 560 on the dyno. But this ld9 is a bit@h. I want 400hp but this trans is holding me back. Last dyno pull did 258hp shock block on 11.7 psi with mad trans slip. Should get at least 300 with a good trans.
