11-29-2003, 07:23 AM
I think my car is leaking!!
The trunkcompartmentfloor is wet. I think it's comming from the wheels when the street is wet, or something like that.
Does anyone know what to do about it?
11-29-2003, 09:59 AM
My only suggestion would be first try to find out xactly where its coming from.
2002 GL2 4DR, MYMODS:In dash 7" VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10" Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
11-29-2003, 10:16 AM
Let's Play Army!
^ yup. check the flap between the window and the lid too. If that ever froze and you opened it while it was frozen, It might have ripped, and could be causing your leak.
Originally Posted by black
11-29-2003, 10:24 AM
The only thing I can suggest is it may be the Trunk Weatherstripping, to check..on a Sunny day close the Trunk with the rear Seats folded down & from inside car look into the Trunk for any light showing through also do the same with a Water Sprinkler running over the Trunk.
Check under Trunk Weatherstripping for Rust or holes.
Next is obvious: look for Rust Especially on the lower part of the Trunk.
Check Trunk Seams for missing or deteriorated Seam Sealer & fix with some new Seam Sealer or whatever is appropriate.
...Dan...
11-29-2003, 10:44 AM
go figure mine too...when it snows somehow the snow gets in there...?
11-29-2003, 12:05 PM
Talk about moisture in the trunk, my daughter was playing with my keys last night and must of hit the trunk button so it was open all night, I go out in the morning and my trunk is filled with snow.
<a href=\'http://members.cardomain.com/r53silver91s2\' target=\'_blank\'>http://members.cardomain.com/r53silver91s2</a>
<img src=\'http://invision.aleromod.com/uploads/post-24-1088131656.gif\' border=\'0\' alt=\'user posted image\' />
11-29-2003, 02:49 PM
ya, i had a samll leak in my trunk, it was the seal around the trunk, it wasnt seated right.
my problem was in a corner, when the car was parked on a bit of an angle, the water pooled in the corner around the trunk, then when there was enough water it leaked over the top of the seal and into the trunk.
11-29-2003, 03:05 PM
my weather stripping thats between the trunk and the bottom of the rear window is pealing off.. its not ripped or anything everything is good, i just need to get some good adhesive so it stays when i push it back on.... any suggestions?
11-30-2003, 01:07 AM
Owner
i did have a water leak in the trunk but after adjusting the trunk seal by adjusting the trunk lid it went away.
Beware of the BackStabber
12-08-2003, 11:47 PM
Bring it to the dealership. should be under warranty. I've had to bring mine in 2 times.
12-09-2003, 12:21 AM
mine leaks like the titanic. but i got like 10 holes in it. lol
12-09-2003, 09:23 AM
10 holes from what?
