06-10-2012, 09:29 PM
Harsh Shifts
On my 2001 olds alero 2.4l 4cyl DOHC it gets to about 3 to 4k rpms shifts like normal then you feel the car jerk and the severity of the jerk is different depending on how hard i hit the throttle. Ive replaced the map sensor transmission speed sensor changed the transmission fluid and filter idle air control valve cleaned every sensor and replaced the Evap Canister Purge Valve Soleniod. Any help would be awesome thanks.
06-10-2012, 10:24 PM
You change the shifter linkage hydrolic fluid?
06-10-2012, 11:20 PM
and sensors unplugged from intake?
Originally Posted by Oldsnut
Originally Posted by tipnitty
06-11-2012, 01:02 AM
No sensors are all plugged in and new. Its a 4 speed automatic so the only fluid for the tranny is the tranny fluid. Im trying to figure out if its something cheap before i tear it apart.
06-11-2012, 07:04 AM
check engine light on?
06-11-2012, 07:06 AM
No. Havent had any codes or anything.
06-11-2012, 11:32 AM
did you replace the IAT sensor? not sure if they are similar but my 3.4 did this when it was shot and the IAT sensor fixed it.
06-11-2012, 12:20 PM
Nope unfortunately my car does not have an IAT Sensor
06-11-2012, 12:48 PM
It should.. my ld9 had it.
06-11-2012, 03:01 PM
^x2
06-12-2012, 07:52 PM
where is it located at i got the part just tell me where to install it. Hopefully this fixes it cause im tired of it happening. and this is what i bought cause this was the closest thing to it. http://www.autozone.com/autozone/par...ier=61396_0_0_
06-12-2012, 08:52 PM
muffler bearings going out?
06-13-2012, 07:11 AM
located on the plactic intake tube that goes to your air box. if you dont have a service engine light on then i will be interested in hearing if this fixes it. something you could try to do (and it may only be temperary) is disconnect the battery for 15 minutes. this will clear all shift adapts and will pretty much give you a clean slate.
06-13-2012, 06:10 PM
Where are the muffler bearings? And I've already done the battery thing and it doesn't help at all
06-13-2012, 06:28 PM
What you perceive as a jerk could feel normal to me. How severe is this?
06-13-2012, 07:19 PM
Its pretty severe like you can literally feel the car jerk forward after it shifts cause it jerks forward pretty hard.
06-13-2012, 07:33 PM
if the IAT sensor doesn't fix it, maybe your transmission is just going bad
06-13-2012, 07:47 PM
I was told by my buddy to check to see if my transmission lines or valve body are clogged do you think that could be the problem cause i really dont have 2gs for a new transmission. Do you think it could be a transmission control soleniod?
06-14-2012, 12:50 AM
ok ive narrowed it down to transmission flush, worn cv axle, MisAdjusted, Disconnected, Faulty Modulator Valve or Improperly Adjusted or Damaged Shift Linkage which one you guys think
06-18-2012, 08:51 AM
transmission flush - could help
worn cv axle - highly doubt it
MisAdjusted, Disconnected, Faulty Modulator Valve - should have a code?
Improperly Adjusted or Damaged Shift Linkage - no. once your in drive... no moving of the shift cable. set it and forget it. not your problem.
