Old 06-21-2012, 11:05 PM   #1
cyl 3 miss
as some of you from ass know. IM having a miss under hard acceleration at higher rpm. i changed out the coils and plugs. it was tuned for the trailblazer injectors. IM still stumped on what it is. IM starting to lean twards the injectors. any insight would be kindly accepted
Old 06-22-2012, 12:03 AM   #2
Still think your just washing out cyl 3 at wot from the injectors not being tuned for your car
Old 06-22-2012, 12:08 AM   #3
Do you have Trailblazer injectors?
Old 06-22-2012, 01:01 AM   #4
yes and i had it tuned for them at ass by cliff
Old 06-22-2012, 02:13 AM   #5
I thought you had the 3500 injectors in... O.o weird its still missing after the tune eh?
Old 06-22-2012, 03:09 AM   #6
Is the number 3 wire arcing or grounding out anywhere? Is it loose on the plug itself?
My car was missing like crazy and I couldn't figure out why. I was playing around under the hood one day and noticed the boots were loose on the plug. Swapped the wires and it's been good, except for the miss at exactly 2600 RPM's cruising speed
Old 06-22-2012, 04:18 AM   #7
Pull the plug and take pictures of it the sparkplugs will tell all
Old 06-22-2012, 07:16 AM   #8
try replacing the wire too. that will rule out the ignition systme at this point (coil/plug/wire). try just swaping the wire to a nother cylinder and see of the skip follows. if your sure the plug is good, then at this point if the skip doesnt change its problem fuel or compression related.
Old 06-22-2012, 08:05 AM   #9
fisdad
It may be as simple as a fouled out plug if you didn't change them during the swap. Try the Autolite plugs next time. I've had nothing but good things to say about them and they are only $2.50 each.
Old 06-22-2012, 09:28 AM   #10
i swaped the plug with cylinder 2 at ass no effect
Old 06-22-2012, 09:29 AM   #11
im gunna try wires today
Old 06-22-2012, 06:17 PM   #12
When you do, as asked, get a good shot of the pulg for us if you can. I am very good at reading plugs bro...
Old 06-25-2012, 05:16 PM   #13
Old 06-25-2012, 06:07 PM   #14
well i changed the wires today. and that solved the issue
Old 06-25-2012, 06:30 PM   #15
Srsly....
Edit, spark plug looks good though.. You can see small indicators of it being submerged into a rich stroke though
Old 06-25-2012, 07:09 PM   #16
yea it looks like that probably because it was missing
Old 06-25-2012, 08:30 PM   #17
Yep
Old 06-26-2012, 02:10 AM   #18
well i looked into the offending wire and found it was split on the inside
Old 06-26-2012, 02:19 AM   #19
nicothehut
nicothehut's Avatar
nicothehut is on a distinguished road
Wire #3 failed in the same way last winter on mine too.
Bessie Braddock: “Sir, you are drunk.”
Churchill: “Madam, you are ugly. In the morning, I shall be sober.”
nicothehut is offline   Reply With Quote
