Pics?
Does the engine look offset to you? Crack out the tape measure and measure the distance from the firewall and the back of the upper manifold on the left and then on the right, or you could do it in the front to the header panel. This will tell you right quick if there's a problem
Yea, the cruise works a lot better when the cable is attached
Don't worry, I had no cruise for a year because my cable would not adjust, then I took the cable off the cruise box, which broke the box
