Old 09-08-2004, 10:39 PM   #1
vanillaman
Can anyone give me some detailed instructions for removing my throttle body, it is pretty dirty and would like to clean it. If anyone can tell me a cleaning solution that would work well, that would be helpful as well.
Old 09-11-2008, 08:47 PM   #2
TheEdgeofSanity
TheEdgeofSanity's Avatar
instead of making a new thread, i revived this one to prove that I used the search button and got no decent results. So, as the person said in 2004, how exactly does one go about cleaning their throttle body? it would be nice if someone could make a write-up for the 2.2, 2.4, and 3.4 because this seems like something that would be important.
2000 Chevrolet Malibu LS
Old 09-11-2008, 08:57 PM   #3
remove the throttle/cruise cables, unplug the sensors/vacuum lines, remove the 4 bolts that hold it to the intake manifold
Old 09-11-2008, 09:14 PM   #4
TheEdgeofSanity
what do I clean it with? what should I expect to see? i have no idea what the inside of a throttle bdy looks like.
Old 09-11-2008, 09:20 PM   #5
guiguilandry
guiguilandry's Avatar
yon can try a good old can of... throttle body cleaner.
Available at any autopart store
Custom or Nothing...
www.demonautosport.ca
Old 09-11-2008, 09:38 PM   #6
haha I didn't even see the date, was responding to the guy's original post about how to remove it
Old 09-12-2008, 01:21 AM   #7
alerored04
alerored04's Avatar
Hose it down with brake cleaner or carb cleaner, both cut through grime great. Wipe it down spray again to get the remainder, wipe again, let dry, reinstall.
My car breaks alot.
Old 09-12-2008, 01:22 AM   #8
Vinalero
Vinalero's Avatar
I used W40 and a tooth brush
