Old 07-14-2012, 08:36 PM   #1
Final500Alero309
Final500Alero309's Avatar
Final500Alero309 is on a distinguished road
Where to buy replacement pacesetter header gaskets for the 3.4 ?
I put the headers on in April. I know I have an exhaust leak at the headers, where do I get replacement gaskets ?
Final500Alero309 is offline   Reply With Quote
Old 07-14-2012, 09:37 PM   #2
http://wot-tech.com/shop/gm-60v6/exhaust/cat_98.html
Old 07-14-2012, 10:49 PM   #3
Final500Alero309
Originally Posted by AleroB888 View Post
Somewhat of a novice, I guess Flanges is another name of gaskets ? Cool, Sady it is my dailey driver. Driving with a leak for too long could really screw up the engine right ?
Old 07-14-2012, 10:52 PM   #4
No, individual gaskets (6 are needed) are on that page:
http://wot-tech.com/shop/gm-60v6/exh.../prod_343.html
Old 07-15-2012, 01:05 AM   #5
only place you can get pacesetter header gaskets is from calling pacesetter them self, believe me ive gone through 3 of them, they are JUNK! i blew my front gasket just about every month. so i said screw it and used copper RTV as a front header gasket. and its lasted longer then those cruddy pacesetter gaskets. if yoh really want to order them here is there number, and this is the only way to order them. by phone. lol
Phone Number
602-266-1964
Old 07-15-2012, 10:50 AM   #6
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Do you know where the leak is? You can probably just use the permatex copper stuff to seal it up if the leak is up front and easily accessible.. It does need 24 hours to cure though, so your car will be out of service for a whole day.
Permatex copper should available at most parts places... I assume places like autozone would carry it.
Old 07-15-2012, 10:58 AM   #7
Final500Alero309
The leak is sounding like it is coming from the headers in the back.
Old 07-15-2012, 12:12 PM   #8
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Oh... I had the head bolts break off on one of the exhaust ports in the front when a friend installed them and he couldn't put a gasket on there so he used some JB Weld to hold it in place and seal the port, but there was still a small leak there... I bought some permatex copper and it did the trick.
Old 07-15-2012, 12:28 PM   #9
Final500Alero309
My dad put that permatex copper seal on when he first put them on
Old 07-15-2012, 01:10 PM   #10
mfuller
If they will work with the Pacesetters (and I can't see why they wouldn't), I'd recommend using the stock metal exhaust gaskets, although you may need to cut them up with a pair of tin snips.
Old 07-15-2012, 03:27 PM   #11
thats a good idea too matt.
Old 07-15-2012, 03:43 PM   #12
Which was in the link I posted in post#2. jeez
Old 07-15-2012, 07:35 PM   #13
Final500Alero309
If I buy a stock gasket from GM, can I just put it on, or do I have to modify it ?
Old 07-16-2012, 10:26 AM   #14
Old 07-16-2012, 11:24 AM   #15
Originally Posted by MMGT1 View Post
We've said that 3 times, now......
oh,noooooz, could it be we been troll'd?
Old 07-16-2012, 11:25 AM   #16
*PLONK*
Old 07-16-2012, 12:32 PM   #17
haha sorry b888 i didnt look at your link you posted
Old 07-16-2012, 09:00 PM   #18
I have the stock metal gasket on the back (right side of engine) headers and I haven't had a problem. Been having problems with everything else that isn't stock.
The tip snips you'll need, is to cut off the extra material that will be exposed.
I need to swap my front gaskets out back to the GM stock one. I'm going to do it after I move, if that's this year, since they are buried in my storage area in the basement
