08-07-2012, 02:48 AM
c pillar in rear help with cutting
i have some tweeters that need some more room to fall flush my questions is before i cut the hole out of the metal behind the pillar is it going to cut to the outside or is our cars 2 pieces put together? i just want to make sure before i cut out the circle that it will only go through one side.
08-07-2012, 03:06 AM
pop it off to cut it.
08-07-2012, 03:15 AM
yea i have the pillar cut already now i gotts cut the circle out of the metal part behind the pillar just want to make sure it wont go to the outside if i do so meaning is there 2 layers of metal.
08-07-2012, 10:40 AM
i dont know why you would start cutting pillars to fit tweeters...
08-07-2012, 12:01 PM
15.65 @ 87.3 MPH
This. They're only tweeters. Just doesn't seem like a good idea. You'd be better off cutting up the tweeter trim piece to get them to fit. Even if they would stick out a bit more, at least you didn't have to cut into a structural pillar just to fit a tweeter.
08-07-2012, 02:40 PM
Add a couple layers of fiberglass on the front of the pillar and make a small pod to give you the rear clearance you need...
08-25-2012, 01:18 PM
there should be no need at all to cut your Pillar. In all my years of being a certified audio installer have I ever had to cut into a pillar to mount a tweeter. Do you not have the factory tweeter pods on the doors above the door panel?
08-25-2012, 01:47 PM
hes putting tweeters in the pillars that run along the rear windshield. not in front.
Originally Posted by Oldsnut
Originally Posted by tipnitty
08-26-2012, 06:03 AM
Well, First of all i agree with others in that you shouldn't need to cut any metal to fit a speaker (with the exp of the occasional door or rear shelf set-up) and that if you are running components in the rear mounting the tweet facing up at the glass will give you more then enough imaging for what a rear stage needs usually...
HOWEVER if you need to have flush-rear mounted forward facing tweeters, with the pillar plastic removed you should be able to identify the inner metal support of the roof (this has holes and such in it, like where the clips for the plastic fit into) and if you stick your finger thru one of these holes, and don't get it stuck meow... you should be able to feel the smooth outer layer...
don't cut/heat the outer sheet metal or you will require bodywork to repair your mistake.
Oh and Btw if you have family friends or loved ones that travel with you.. and you cut some of this structural tin out.. and you roll your car and the roof buckles/fails your insurance company/law enforcement will site you for negligence. food for thought.
08-26-2012, 06:37 AM
I agree. So what if they are not completely flush. You should NEVER cut into framework on a vehicle. You're just asking for trouble. Think of it this way, my father always told me; "engineers get paid a lot more than you do to figure out why that metal should be there. Don't argue with them"
