Old 08-07-2012, 04:43 PM   #1
redrider07
redrider07's Avatar
redrider07 is on a distinguished road
T-10 Leds under dash
I want to swap the stock lights for the dash for T-10 leds (194). There was a previous right up to use inverted T-10. Can you use focused leds, or do you have to use inverted because of the way the dash looks? Also, some bulbs have 3 or more leds on them, but would that be too bright under the dash?
redrider07 is offline   Reply With Quote
Old 08-07-2012, 05:29 PM   #2
jhubbz
⌘ Irish Pride
jhubbz's Avatar
I currently have 194 5-smd blue LEDs as my dash and it looks great! All you have to do is pop out the old bulbs and put the new ones in the old sockets. I soldered them into the socket for good measure.
Done lost my mind
Old 08-07-2012, 05:45 PM   #3
redrider07
redrider07's Avatar
Sweet thanks jhubbz, i was afraid maybe running a bulb with too many leds would burn out the board, but as long as they are 12 volts that should be fine right? Does the dash dimmer switch still work with the leds, can you dim them at all?
Thanks man
Old 08-07-2012, 05:50 PM   #4
redrider07
redrider07's Avatar
Car looks good by the way....I am trying to decide between red and blue. I has some previous halo white gauges and one of the connectors broke, so the fuel light does not light up now, the rest do! So, I am going to go back to stock gauges except I want blue or red bulbs. The only thing that worries me is that the old white face ones have a wire that connect, and when I follow it it goes deep into the car, I think for the inverter. I might just cut it, seeing I am going back to stock gauges instead of white face, and they don't use the inverter!
Old 08-07-2012, 09:38 PM   #5
jhubbz
⌘ Irish Pride
jhubbz's Avatar
LEDs are usually not meant to dim. There are dimmable LEDs out there, but you have to look for em. If you try to dim regular ones, the resistance might burn out the LED. I just bypassed my dimmer (doesn't work at all) just so I don't do this.
Done lost my mind
Old 08-08-2012, 10:06 AM   #6
rocketfast321
rocketfast321's Avatar
rocketfast321 is on a distinguished road
I had pre wired LEDs installed under my dash connected to the theater lighting. They would dim to about 1/3 before going out. No problems with them.
rocketfast321 is offline   Reply With Quote
Old 08-09-2012, 10:06 PM   #7
k.house73
k.house73 is on a distinguished road
Okay I might sound dumb here but I'm pretty new with changing out bulbs... Do the bulbs in the dash not come out of the socket??? Or how do you change them? Like I said, new at all this...
k.house73 is offline   Reply With Quote
Old 08-10-2012, 12:51 AM   #8
Just pull em out yo you may have to twist em. Its been years since ive messed with anything
Old 08-10-2012, 08:45 AM   #9
jhubbz
⌘ Irish Pride
jhubbz's Avatar
The ones already in there will twist out fairly easy, but the bulb will take some effort. On some models, there will be a small hole on the bottom of the socket that you can poke something through and pop the bulb out.
Done lost my mind
Old 08-10-2012, 09:27 AM   #10
k.house73
Cool thanks!
