09-13-2004, 04:57 PM
Just wondering if anyone can tell me how to replace the water pump, thanx
09-13-2004, 05:59 PM
what engine
09-13-2004, 06:17 PM
2.4l
09-13-2004, 10:46 PM
Owner
the water pump.....................lol
well it is a big job. it is located by the exhaust manifold. let me see if i can get ya a how to.
Beware of the BackStabber
09-13-2004, 10:52 PM
Owner
here you go how to replace water pump
09-14-2004, 11:45 AM
wow, thanx Scott, looks like I've got quite the project ahead of me <_<
09-14-2004, 12:14 PM
09-14-2004, 12:16 PM
I just read over that link and I must I'm damn glad to have the V6. You can have the water pump on those changed in about 30 minutes.
09-14-2004, 08:07 PM
has anyone done this by themselves b4? the cheapest person we could find said it would be 460 bucks, and the water pump costs like 60 <_< .
I need to know if you think with the right tools (someone said they would let me borrow tools) and no lift, just jacks, that I could do this by Saturday? I really want to have it done by Sunday, there are some drags there. The mechanics might not be able to have it done until next thursday or somethin like that...
09-14-2004, 09:06 PM
Owner
that isn't bad for cost wise. i have heard of it costing $700-$1000. but that was a dealership.
well if your knowledge of motors is very small then i would say no. see if you can get someone that knows about engines to help ya. this is not a newbie job.
09-14-2004, 09:08 PM
Owner
this is one downfall of the 2.4
but at least i can change my belt in 1 minute
change plugs in 10 minutes.........etc
pros and cons too both motors
09-14-2004, 09:11 PM
great, I'm screwed
09-14-2004, 09:17 PM
ummm, not really. not if the drain plug is stuck at least
09-20-2004, 05:59 PM
Is there a how-to for the 3.4 to change the water pump
05-13-2005, 04:01 PM
To replace the water pump for the 3.4:
remove the radiator overflow tank - 3 hoses, 1 bolt, 1 sensor
remove the little belt installation direction piece (above the water pump and just one bolt)
release the tensioner pully (3/8 ratchet)
remove 4 bolts on front of the water pump; you may have to use a screwdriver or a wrench to prevent it from turning while you remove them
remove 5 bolts holding the water pump to the engine
use a gasket scraper and scrape all the old gasket crap off
clean out any crap from the hole
put on the new gasket
put on the new pump
reattach the outer pully cover
retension the belt
replace the sensor and radiator overflow tank
turn on the car and heater on high and fill up the tank till its full
you may get some bleed out of the water pump until the water gets to the right level
enjoy a functional water pump (mine was 20 something dollars at advance)
08-20-2005, 02:15 PM
Does anyone have the working link for the how-to for replacing the water pump. Started into the project not knowing what we got into now were so far that its not worth turning back. Any advise would be great. So far have the exhuast manafold off half the time chain cover. Does the whole cover need to come off?
