04-19-2013, 12:51 AM
Milzy transmission mount install
so I bought this "used" and went to try and install it... but I cannot for the life of me figure out how it bolts up... the bolts included just do not seem to make sense with how it should go in...
anyone have this installed and how did it work, or do I somehow have the wrong bolts? it was purchased from miltzy, but never installed...
from the look, the top 2 bolts should go into where the stock one mounts, but the top one looks like it should also go through the poly bushings... but it is also the only one that goes all the way through the bottom hole... if that makes sense...
please help!!!
thanks
04-19-2013, 03:30 AM
The longer bolt goes in the bottom hole. You reuse the stock bolt that goes through the bushing. The mount goes near the front not the side one...how it bolts in should only work one way. I can't imagine how much of a pain in the ass it must be to put it on with the engine still in. Make sure to torque those suckers too. Hope i helped....i was kind of confused by your post lol
04-19-2013, 07:06 AM
milzy! not miltzy
Originally Posted by Oldsnut
Originally Posted by tipnitty
04-19-2013, 09:29 AM
Lol thanks Billy!!! Never even crossed my mind to reuse a stock bolt!!! That makes sense now that someone else gives me perspective hahaha...
04-19-2013, 11:04 AM
yeah the through-bolt gets re-used because it's dimensions don't get changed. the other bolts are longer than factory, so we have to supply new bolts.
if you have bolt-in fans, removing the one on the driver's side makes this much easier. if you have riveted in fans, have fun.
www.milzymotorsports.com
04-19-2013, 10:35 PM
hahaha... thanks Mike... got your email about it too... I was playing around with it just before I posted it, and it didn't look too bad... ill give it another whirl next chance I get and if I remember ill take some pictures!!
cant believe I didn't even think of reusing the stock through bolt... duh!!
04-20-2013, 08:47 PM
i wish milzymotorsports.com accepted paypal and Billmelater. id have a ton ofparts on my doorstep if it did lol
2003 V6 gl coupe. Mods: cold air intake, Resonator Delete, GAGT muffler, GAGT torqued 5 spoke rims, grand am pre02mirrors ,cross drilled and slotted rotors by powerstop, 1999 hvac blue knobs
04-21-2013, 09:54 AM
Tim, you should have shot me a text man. You know I've been bugging you since day one about installing one!
And Milzy, you don't take paypal dude?
04-21-2013, 09:58 AM
someone needs to do an install thread I plan on getting one
04-21-2013, 01:34 PM
Lol Paul!!! I've had it since you before you did my tune... just haven't had time to install! I sent Lyndon a text asking him to get me a picture so i could see it... wasn't sure if you would have remembered how it got bolted.down hahahaha
I'll try to take some pictures depending on lighting and post my version of a how to...
04-22-2013, 03:51 PM
we definately accept paypal.
04-23-2013, 11:08 AM
I thought you did man, was thinking something has changed. Well there you go 03, order away bro!!
