Old 06-07-2013, 10:19 PM   #1
How-to, Radiator Drain Plug / Valve
No leaks for 2 days, so here we go:
New plug, slightly different than original plug:
Original one was stuck, the 1/4 inch square bit just stripped it out. I used a slip pliers to remove it, but the metal pin that holds it in broke. It would go back in and seal ok, but work it's way back out.
(uh, the bottom is actually on the righthand side of the pic )
Open the cap on the overflow reservoir tank to relieve pressure, then close it again to create a vacuum in the system. Then clamp the lower radiator hose (on the driver's side):
Remove original, install replacement. It was not necessary to drain the system in this situation, very little coolant came out as you can see:
Old 06-07-2013, 10:51 PM   #2
Starglow
Starglow's Avatar
Starglow is on a distinguished road
I did that on my GA too.
Starglow is offline   Reply With Quote
Old 06-07-2013, 11:00 PM   #3
04PONTIACGA
04PONTIACGA's Avatar
04PONTIACGA is on a distinguished road
Nice, I see you visited the help section at your FLAPS.
04PONTIACGA is offline   Reply With Quote
