Old 09-17-2004, 09:39 AM   #1
HAZED
ok i get in my car about noon turn on my car front headlights on.. i thought the
lights come on at night not during the hot bright sun light anyone else have that
problem.is there any way to bypass it? thanks
Old 09-17-2004, 10:09 AM   #2
misslindseysue
Did you have anything up on your dash? If you're covering the sensor it could thing that it's night. Otherwise, did you turn the lights on? That's the first thing I'd check. I have a habit of forgetting to turn them off on the rare occasions that I override the auto feature when it's not quite dark enough.
If not either of those, check your fuses and stuff, I'd guess that the headlights fail on.
Old 09-17-2004, 11:11 AM   #3
Travis99Alero
i think he's taking about the drl's. as for bypassing them, try using the search function.
Old 09-17-2004, 11:29 AM   #4
misslindseysue
Perhaps.
Old 09-17-2004, 11:47 AM   #5
99ALERO
well as i read it, it says he got in his car and turned them on?
Old 09-17-2004, 11:50 AM   #6
HAZED
im saying that they (front lights) R on all the time and no i dont have anything on the dashto block the sensor ive blown with a air can just to c i t hade dust but nothing
Old 09-17-2004, 12:05 PM   #7
b-spot
b-spot is an unknown quantity at this point
Daytime Running lights my friend. Its a safety feature.
If I did went to college...
b-spot is offline   Reply With Quote
Old 09-17-2004, 12:48 PM   #8
HAZED
nope it aint daytime running lights u mean your lights stay on all time while u running
your car even in the day time
Old 09-17-2004, 12:58 PM   #9
j-work
Senior Member
j-work is an unknown quantity at this point
Yep, DRL's stay on all of the time except at when the headlights are on. They are the instide light, your headlight are the outside lights.
j-work is offline   Reply With Quote
Old 09-17-2004, 01:05 PM   #10
MACBUYA
Not necessarily, on newer aleros the DRL are the regular headlights, not the brights.
HAZED- look around when your driving, all newer GM cars will have their lights on whill in drive.
Old 09-17-2004, 01:09 PM   #11
sound_xtreme
sound_xtreme's Avatar
yea they switched them in like 03 or something, DRL's run off the Regulars and the brights are ONLY used for brights.
But yea, your headlights should always be one. They are called DRL's. there's way to bypass them.
Cardomain
Old 09-22-2004, 03:21 AM   #12
HAZED
wouldnt my lights burn out sonner!!!!
Old 09-22-2004, 03:27 AM   #13
Crolero
^^^ safety first.
Old 09-23-2004, 08:13 PM   #14
99ALERO
mine havent burned out yet
Old 10-10-2004, 02:12 PM   #15
arche
i have had the same problem with my headlights being on all the time, not the DRLs. i know it's the headlights because my fog lights are on all the time too. i'm thinking that the relay that controls the automatic headlights has gone bad and they just default on. does anyone know a part number for this relay? where it's located? how to replace it?
Old 10-10-2004, 09:48 PM   #16
Originally posted by 99ALERO+Sep 23 2004, 08:13 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (99ALERO @ Sep 23 2004, 08:13 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-HAZED@Sep 22 2004, 02:21 AM
mine havent burned out yet [/b][/quote]
They use a lower wattage to run, They are not as bright as they are at night
