Old 06-08-2013, 12:18 AM   #1
Blaze
Blaze's Avatar
Blaze is on a distinguished road
weird break wear
Has any one had or seen this? this is off my 2002 gls.
Blazin
Blaze is offline   Reply With Quote
Old 06-08-2013, 01:10 AM   #2
seized caliper, or you need to change your rotors.
Old 06-08-2013, 01:23 AM   #3
Starglow
Starglow's Avatar
Starglow is on a distinguished road
Those rotors are nasty looking....definitely would replace them.
Starglow is offline   Reply With Quote
Old 06-09-2013, 07:39 PM   #4
Blaze
Blaze's Avatar
The cliper is fine I changed pad/rotor I'm going to upgrade to corvet and comaro parts.
Blazin
Old 06-09-2013, 07:42 PM   #5
Blaze
Blaze's Avatar
I thought the slide bolts were going bad however only the. Inside pad and rotor is bad.
Blazin
Old 06-09-2013, 08:23 PM   #6
inside pad rotor, usually means un even wear/breaking pressure. even though it may not seem like it, but imo i think the caliper is on its way out soon.
Old 06-10-2013, 07:03 AM   #7
your pics show typical rust build up on the rotors and that is the cause of the weird pad wear. if nothing was stuck and you could compress the piston then theres nothing more that needs to be said.
Old 06-10-2013, 07:06 AM   #8
Good point, didnt really look at the rotor to much, now I see that there is little pressure area that is unrusted.
