Old 07-01-2013, 11:44 AM   #1
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
NoSweat83 is an unknown quantity at this point
Bad Strut Mount
As some of you know I didn't make ASS this year. This was due my car having an inconsistent shake after getting to 55 mph. Think I found the problem...
NoSweat83 is offline   Reply With Quote
Old 07-01-2013, 12:44 PM   #2
Ill take the setup if you don't want it :-)
Old 07-01-2013, 12:55 PM   #3
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
Under weight the strut mount shouldn't move though....
I would agree with you if the strut was able to be press fitted back in the mount. I could be wrong here, but that loose fit could be giving me the vibration at speed and if that's the case, it will only get worse as it wears.
Old 07-01-2013, 12:58 PM   #4
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
Hahaha! I'm sending both front struts back to Ride Tech for them to to be modified/repaired.
Old 07-01-2013, 02:56 PM   #5
Gotcha can you lay frame with those?
Old 07-01-2013, 03:02 PM   #6
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
Nope. The Easy Street's get lower, but those didn't either. I know Bdyman was talking about modifying them so, he could. Don't know if he ever did though.
Old 07-01-2013, 05:05 PM   #7
That's your second set iirc what was the first set?
Old 07-02-2013, 03:41 PM   #8
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
These were my first, made the switch to easy street, and switched back.
