07-07-2013, 06:29 PM
the making of my new tail lights
07-07-2013, 06:53 PM
Wow very good job!!! But... I dont like how you did the brake light for the tails. I hope you dont get in an accident.
Originally Posted by Oldsnut
Originally Posted by tipnitty
07-07-2013, 09:08 PM
Yes great job, what do the reverse lights look like?
99 Alero 2.4
Expect the unexpected.
07-07-2013, 09:10 PM
Look stock, just tinted over.
07-07-2013, 10:10 PM
those look pretty wicked man!! just in my own personal opinion, I would have reversed the rings... had the small ring as the running light and the larger outer ring as the brakes... make it as visible and distinct as possible... gonna have to see them in person soon
07-07-2013, 10:15 PM
Those look sweet! I would have made the rings more spread out for better definition. Or two rings of brakes and one running. I'm paranoid about getting rear ended.
07-07-2013, 10:54 PM
the reverse are just the plain bulbs and you can't see the third break light but I but I fix that and its easy to see the breaks ill take a good picture of breaks tomorrow
07-08-2013, 08:53 PM
Did I mention my paranoia? I had mine made special so that all 4 lot up as brakes just in case.
07-08-2013, 10:05 PM
what kind of breaks, lunch breaks? glass breakage?
07-09-2013, 04:23 PM
How did u get them apart and did u reuse the stock covers
07-09-2013, 04:25 PM
They don't look THAT bad but something about the part of the tail light that is connected to the trunk just looks empty with one set of rings near the inside.
Mods: Lowered on Canuck springs(1.75") on KYB GR2 struts with monroe mounts. SC/T hood/spoiler. Amber corner black housed headlights. Red LEDs for window/lock switches. White LEDs for map/floor/glovebox lighting. DRL and ALC delete. 20% Tint. 35w 3k HID fogs. Sport Edition KV5 Silver painted 18x8 35mm offset. Bridgestone Potenza RE970AS Pole Position tires. Badge delete. 12" PowerSlot slotted front brake upgrade w/ firebird dual piston calipers, rear slotted rotors. Borla Cat-back exhaust.
07-09-2013, 05:11 PM
I know what u mean after I was done I started thinking what if I used 12 rings instead of 8.
and I cut them apart with a dremal and yes I did re use the lens
it really wasn't that hard to make just time consuming, the led strips cost the most
07-09-2013, 05:31 PM
and of course there's no running lights in the day so its easy to see the "lunch breaks" when there applied in the day. but you really gotta see them in person too get a good look at them if you've ever bought leds from superbrightled.com you'll know what im saying. although it would be cool to have the running lights dim then brighten up when the breaks are hit how ever that's done.
07-09-2013, 05:46 PM
so did the lights sit further in because they were cut?
07-09-2013, 05:47 PM
and whats up with the cloths pins
07-09-2013, 06:23 PM
I think they were holding the rubber lining to the lens.
07-09-2013, 07:19 PM
yes they was holdin the rubber to the lens and they sit pretty much stock because of the rubber on the lens
07-09-2013, 07:27 PM
I still give props for doing this, just not a fan of the way you went with them. And vht wears off after awhile just fyi, i had to redo mine quite often when i had tinted tails, you should look into a clear coat/black paint mix for the tails. They will be really shiny and wont fade.
07-09-2013, 08:06 PM
is there a store that sells that or a brand you recommend, I did clear coat them to - three times..... plus im most likely buying a new car within a year
07-09-2013, 08:26 PM
You can mix it yourself, or find a paint shop that will do it.
