Old 07-23-2013, 07:20 PM   #1
Silver SLP
Silver SLP's Avatar
Silver SLP is on a distinguished road
Trailer Light Wiring
Just got a new Curt hitch installed. Now I just need to wire the trailer lights...
I know on the adapter that Left Turn is Yellow, Right Turn is Green, Tails are Brown and the ground is white.
So my question is, what do those colored wires go to on the stock tail light harnesses? I don't have a test light tool available at the moment...
Thanks!
Silver SLP is offline   Reply With Quote
Old 07-23-2013, 08:35 PM   #2
Can't find the wiring diagram on the net, but I do have a wiring diagram at home, I can tell you later (at work now)
I too have the trailing wiring, but I forget which is which, but I do remember I put the little box under the left taillight and I rigged a zip tie like a loop to hang the wiring plug up and out of sight. Did that on the Delta too
Old 07-23-2013, 09:24 PM   #3
i attached my plug to the hitch itself, nice n clean and out of the way, had to run it through a gromit in the trunk, ill get a pic when i go get the alero
Old 07-23-2013, 09:57 PM   #4
Silver SLP
Silver SLP's Avatar
Much appreciated!!
Old 07-24-2013, 02:17 AM   #5
Left: Light Blue/Black
Right: Dark Blue
Stop/Tail: Brown
ground: Black or to Body / chassis
Old 07-24-2013, 02:20 AM   #6
Silver SLP
Silver SLP's Avatar
Right: Dark Blue
Stop/Tail: Brown
Thanks a lot I'll wire it up tomorrow after work!
EDIT: I also had to wire the 'red' lead from the new harness to the 'light blue' wire on the car. (No black stripe and also on drivers side.)
Red is for brake lights.
