Old 01-11-2014, 08:34 AM   #1
03Alerosil
03Alerosil's Avatar
Fpr+throttle body
I need to replace my leaking fuel pressure regulator. The I ring is leaking but I just got a new regulator. My question is do you have to remove the throttle body and if so is there a way to do it without taking off the coolant lines that run under it? If I do end up taking it off I plan on cleaning it
Old 01-11-2014, 11:09 AM   #2
If you take those lines off the car leaks little to no coolant.
Old 01-11-2014, 12:53 PM   #3
03Alerosil
03Alerosil's Avatar
Oh that's good to know. Maybe I just replace them being they gonna be off and I will have to bleed the air out anyway
Old 01-11-2014, 01:46 PM   #4
i think i was able to replace the FPR o-ring without doing much if anything at all other then removing the fpr. its been a while though, i could be wrong.
Old 01-13-2014, 09:08 PM   #5
03Alerosil
03Alerosil's Avatar
Replaced my regulator. Left TB on. Just propped throttle open. Cleaned iac,maf,iat while I was at it. Car runs great
