Old 01-15-2014, 09:23 PM   #1
Alternator power wire.
Status: FIXED
Somehow I screwed up the wiring for my car and the Alternator has 0 voltage from its power wire to the negative terminal on the battery. Starter has 12 volts and the car starts, it just runs on battery power.
Does anyone have a diagram tracing the wire from the alternator back to the battery?
I haven't torn into the wire loom yet to find the disconnect, but I'm assuming either:
  1. The wire from the starter loom area to the alternator is melted/broken from the short I caused a few days ago (I had the power/ground for the starter switched).
  2. I have some wire crossed at the ground area or starter.
I will open the loom tomorrow and see if anything has been damaged but is there anything I could possibly be missing? Is there a fuse from the starter to the alternator?
Old 01-15-2014, 09:37 PM   #2
there is a fusible link on the alternator cable (circled), between the alternator and starter. just because the schematic shows it down near the starter DOES NOT mean its down near the starter. could be closer to the alternator.
Old 01-15-2014, 09:42 PM   #3
Edit: Actually.... I don't have the 2nd smaller wire connecting to the starter solenoid.
Wow I'm dumb. I connected that wire to the grounds. So it basically does nothing. Lol. That's the alternator wire. I just need to connect it.
Old 01-16-2014, 06:20 AM   #4
Nas Escobar
Nas Escobar's Avatar
Yeah, I was going to say... You're not supposed to connect the alternator to the ground.
Glad it was just a minor mistake.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Old 01-16-2014, 06:34 AM   #5
Never says he connected the alternator to the ground. Just checked voltage between the alternator and ground. If everything is perfect you should have battery voltage present.
Old 01-16-2014, 07:57 AM   #6
I technically did though because the green wire that I connected to the ground is the positive source wire for the alternator. So right now the alternator is just grounded and not doing anything.
Old 01-16-2014, 09:13 AM   #7
I see. They way you said it in the op i just assumed you checked voltage like that ( which is a valid test)
Old 01-16-2014, 08:22 PM   #8
Nas Escobar
The way I read it, there was one cable going from the + of the alt to the - of the batt.
1996 Infiniti G20
Old 01-16-2014, 11:47 PM   #9
Essentially. Cable going from the + of the alt to the - engine block bolt. All better now, easy to mistake when you don't label anything or use a multimeter when you do an engine swap. lol
