Old 02-22-2014, 08:19 AM   #1
thegoat54
thegoat54 is an unknown quantity at this point
Misfire under load - No codes
Hi everyone.
I have a 2004 Alero with the 3400.
Getting a misfire under load. Notice it mostly when approaching a hill and trying to maintain speed.
It is getting worse, and yesterday it misfired to the point where to Check Engine Light was flashing. I can't get the engine to throw a code though to help me out.
I replaced the plugs a couple months ago, but not the wires. Those are original. I'm thinking the wires?
Any help is appreciated.
thegoat54 is offline   Reply With Quote
Old 02-22-2014, 10:44 AM   #2
RalphP
RalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond repute
Wires is what I'd be checking next, yes.
However - if you can find a dark enough place, what you can also do is take a spritz bottle filled with tap water, and while the motor is idling in the dark, spritz the spark plug wires.
If you get a "blue fire" around the wires, they're certainly bad
Also, treat the coil packs the same way, in case you have a bad coil pack.
Further, if you have an Android device with Bluetooth, it may be worth while finding a good ELM327 Bluetooth OBDII module and installing Torque Free on your cell phone / tablet so you can see why it's blinking the "Check Engine" light.
With the age, though, replacing the wires may not be a bad PM type thing irrespective.
Two things - 1) Don't forget to use the proper boot grease. 2) Do them one at a time so you don't forget where each one goes.
RwP
RalphP is offline   Reply With Quote
Old 02-22-2014, 07:03 PM   #3
^^ what he said! Good tips there... You can also check resistance of the coils to ensure you haven't lost one. They should all read between 5-7K ohms each when tested
