06-01-2014, 09:35 PM
Sunroof switch removal from headliner
Hello all.
I've got a 2003 Alero Coupe. My sunroof recently stopped working. It's stuck in the closed position. I haven't got around to diagnosing the problem yet, but after I check the fuse, i want to try to test the switch with a voltmeter.
I'm wondering if anyone knows how to remove the switch from the headliner. Does it just pop out with a bit of prying? Does the headliner have to come down first? I'd rather not mangle the switch by prying on it blindly if possible.
Thanks for any insight!
06-01-2014, 11:20 PM
It does pop out but there are two small springs that control the switch to keep it from just randomly opening.... be careful if you try!
06-03-2014, 06:38 PM
Thanks!
Are the springs sealed inside the switch or are they going to pop out when I separate the switch from the headliner?
I was just in the car a few minutes ago, and it seems to be working again. I'm not sure if I should trust it though so I’ll still investigate further.
06-03-2014, 06:46 PM
It's a two piece switch but it's loosely held together.... if you pull or pry the wrong way you'll separate the switch and the springs will fly!
Like I said take your time and you should be fine
06-03-2014, 06:58 PM
Alrighty, thanks again!
