09-26-2014, 05:15 PM
Please help, need a link.
I'm getting the ABS, SVS, Trac control lights and am due for an inspection. I remember finding before how to fix this but can't now, can somebody send me a link to a thread about this? Far as I know it's about the Wheel Speed Sensor which can't be replaced without replacing the hub. At least that's what midas told me. Is this correct?
09-26-2014, 06:04 PM
Yes. You have a bad hub assembly.
Remove wheel, remove caliper, remove rotor, unplug abs on backside of wheel hub, turn the wheel all the way right, remove 1 bolt, turn the wheel all the way left, remove other 2 bolts, total of 3. Pull hub assembly off, install new in reverse order. Pretty easy.
Originally Posted by Oldsnut
Originally Posted by tipnitty
09-27-2014, 03:24 PM
One little piece of info for you. If you reuse the stock axle nut (probably won't need to, they usually come with a new one) torque value according to the service book and dealer is 284ft lbs. The new nut only requires 173 ft lbs.
09-27-2014, 10:24 PM
09-28-2014, 01:23 AM
15.65 @ 87.3 MPH
Originally Posted by a.graham52
The search button. Utilize this.
09-29-2014, 06:24 PM
Like I said, I did but couldn't find it again, luckily user a.graham52 linked me exactly what I found before thank you sir!
09-29-2014, 07:00 PM
Please feel free to post pics of your car, projects done or want to do, or just say 'hi' every once in a while.
We are here for more than to fix broken cars
09-30-2014, 03:32 PM
Thanks, posted a few projects in the Audio section already. Very helpful and friendly community you put together here. Where should I buy a new stock replacement hub? Don't wanna screw it up.
10-01-2014, 12:22 PM
If you can't wait, Autozone or somewhere nearby. They go for around $75-$80 us or so around my place. The cheapest rear hub at Autozone is $60 near me. If you don't mind waiting a few days for shipping, rockauto.com is great.
Edit: looked up prices
The cheapest for the front hub is $35.79, which I would only do as a temporary measure, since the part is so cheap. At least until you save enough for a better one, like Raybestos, Timken or Moog. The cheapest rear hub is $43.89.
10-01-2014, 02:47 PM
Wow i did exactly that before i even read this ha. And I went with the $35 one too. Was gonna go with raybestos but money is short and inspection is up
