Old 11-23-2014, 09:26 PM   #1
alero2000canada
alero2000canada is on a distinguished road
alero 2000 electrical issue
good day to you all
i have an alero 2000 3.4 v6 gl
and the problem started with the gauges going a bit mad and the car not starting.
so i checked all the earth/ground connections,even that tricky one on the engine under the exhaust,they were all fine.
battery was checked and is fully charged and connections all good.
so i ripped out the dash and replaced the ignition switch.
stuck everything back together and still the same.
so i got an OBD reader to see what codes are on the cars brains ( would this be the BCM?)
the OBD reader couldnt find the BCM.we tried several times.not found
so my thoughts is the BCM is toasted,would this be correct or am i missing something here.
please note this car has 280,000 kms on it now
alero2000canada is offline   Reply With Quote
Old 11-23-2014, 11:20 PM   #2
Did you test the alt? It could be going out but with the battery fully charged it's unlikely...
