Old 01-28-2015, 05:17 PM   #1
Mtaltocowboy
Mtaltocowboy is on a distinguished road
Mustang wheels
image.jpg Has anyone ever seen these type mustang wheels on an Alero . Ive heard they will fit .
Mtaltocowboy is offline   Reply With Quote
Old 01-28-2015, 06:38 PM   #2
I posted on the fb group that they are a 5x114.3 with a centre bore of 70.6...
You'll need a hub ring to go from the alero's 70.3 hub centre to the mustang 70.6...
Unfortunately i haven't found anything on the width or offset of the mustang wheel... probably the only way is to put one on and see if it clears the brakes, lower strut perch and fenders for front turning radius... from what i know the mustang rims from the mid 90's fit
Old 01-28-2015, 06:45 PM   #3
Mtaltocowboy
I did some research and found that the wheels I have are off of an 05/06 V6 mustang . According to what I can find , the hub on 05-09 is 70.3 like the Alero. I was just hoping to see some pics of what they look like on the Alero . Ive also found a set of Intrigue wheels I may pick up .
Old 01-28-2015, 07:31 PM   #4
Gotcha! I think you'll have to put them on the car yourself... most people here have put full on aftermarket rims on their cars not stock wheels from another car... there's been a couple but most stuck with a gm product... as far as i know anyways!
Old 01-31-2015, 03:55 AM   #5
Nas Escobar
Nas Escobar's Avatar
Most Mustang wheels from the SN95 days (that's the 95-04 Mustang) up to the current one (if they haven't changed the bolt pattern) will fit the Alero and any other GM FWD application. Fords RWD bolt pattern is GM's FWD one. So in theory you can bolt up Crown Vic or Explorer wheels onto your Alero as well HOWEVER be aware Cobra wheels (Which are 18x9) will not fit. They clear the brake stuff fine, have a tight turn clearance but they stick out the fenders. Everything else should fit though, so long it's not wide.
Those wheels show up on CL a lot. Try looking for em there and ask the seller if you can test fit em. Then turn the steering wheel left and right, and spin the tire. You should see if it will rub or not.
BTW The Mustang wheel is 70.3, not 70.6 center bore. The offsets is what changes and 5x115 vs 5x114.3 is so minimal that you don't notice the difference.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Old 01-31-2015, 08:50 AM   #6
I looked up that wheel and it said 70.6 centre bore... that's with the information i was given with it being a 2010 model!
Old 01-31-2015, 01:16 PM   #7
Nas Escobar
Really? I've seen some 2011s being sold as 70.3... Interesting.
1996 Infiniti G20
Old 01-31-2015, 02:35 PM   #8
Motorsport tech
Purchase Wheel Adapters
Wheel Adapter Configuration*********************
2010 FORD MUSTANG_GT
Your Bolt Pattern: 5x114.3mm
Your Hub Diameter: 70.6mm
Yup... went to www.motorsport-tech.com
