Old 04-22-2015, 07:48 AM   #1
03Alerosil
03Alerosil's Avatar
Horn Opinion
Hey guys,
I got an 03 Alero and the brass colored plate that grounds the horn in my steering column is messed up. So I took the pin out of my multi function switch to disable the horn. I thought about replacing the plate but I don't want to damage the steering wheel as I have heard they are hard to remove even with a puller. Could I wire the ground wire for the horn to a 10 amp push button and just mount it on my dash next to the hazard switch? My alero doesn't have to be pretty, just functional. I would like any thoughts on this. Thanks guys
Old 04-22-2015, 08:10 AM   #2
I was going to put mine on a push button or toggle switch as well. Just never got around to it. I wouldnt pull the steering wheel just to fix that, good choice. Even with a puller mine cracked and made it unusable. If you want to keep the horn mount a push button somewhere, should be fine. I've disconnected mine and pulled the fuse, been without it pretty much since I got the alero. Been a few times I wish I'd had it though..
Old 04-22-2015, 06:26 PM   #3
jokerl90
jokerl90 is on a distinguished road
I would be interested in this also. My horn gives a short beep after the doors are locked, but I can't make it blow on the steering wheel anywhere.
jokerl90 is offline   Reply With Quote
Old 04-22-2015, 09:34 PM   #4
03Alerosil
03Alerosil's Avatar
The horn beeps when you lock the car cuz the BCM is grounding the circuit.
Old 04-22-2015, 09:34 PM   #5
03Alerosil
03Alerosil's Avatar
Thanks papa. It should work. I've been without a horn for awhile.
