Old 06-05-2015, 08:54 PM   #1
01OhioAlero
01OhioAlero is on a distinguished road
Werid acceleration and start up issues
I just did a few things on my car, it has new lim gaskets and up. Now it wont start unless I prime the fuel pump a few times, even though once and you can press the fuel rail and it has great pressure. It idles rough for a while then settles down to perfect. It revs up in park and neutral great. But in drive I cant go above 3500 rpm. When I do it just stops moving almost and tach just climbs. If I slowly keep a constant 1/4 throttle I can eventually get it moving but If I go WOT it just barely moves and the tach goes up. Im thinking TPS or a bad cat? Also my oil pump clamp is leaking, anyone know why? I tightened it down and it still leaks. And the valve covers leak even though they have new gasket and are tightened down good. Any ideas for the valve covers?
01OhioAlero is offline   Reply With Quote
