Old 10-02-2015, 11:33 PM   #1
LD9 Alero
LD9 Alero's Avatar
LD9 Alero is on a distinguished road
Fuel Leak
Hi all, on my mom's 2001 2.4 Alero, one of the fuel lines at the back of the engine, has begun leaking. I'm not sure if it's the feed line, or the return line, any ideas?
My Vehicles:
2001 2.4L Alero GL1 Sedan (mom's old car)
1995 Chevrolet G20 5.7L
2004 Mustang GT (daily driver)
LD9 Alero is offline   Reply With Quote
Old 10-05-2015, 08:13 PM   #2
As a temporary repair, you might be able to use a pipe cutter and cut out the large diameter metal part that connects to the rubber part, and cut the rubber section out that has the leak. Then add a new section of hose with hose clamps and an inline brass connector. Then order a new complete hose assembly if you can.
Old 10-05-2015, 10:50 PM   #3
LD9 Alero
LD9 Alero's Avatar
I found the part number of the hose assembly (24576680), and it doesn't look too hard to replace it. Is there a preferred site to order discounted GM parts, like how Ford has Fordparts.com?
My Vehicles:
Old 10-06-2015, 12:32 AM   #4
That01Olds
That01Olds's Avatar
That01Olds is on a distinguished road
There is GMPartsDirect.com or Rockauto.com. The 2nd one is a site sponsor and they usually offer discounts on parts to members of the site. For example they currently have a 5% off discount code that expires on November 17th, 2015.
Check out the link to this thread for the discount code and more details pertaining to it.
http://www.aleromod.com/forums/showthread.php?t=38491
That01Olds is offline   Reply With Quote
Old 10-06-2015, 01:25 AM   #5
LD9 Alero
LD9 Alero's Avatar
I'll check them out, thanks!
My Vehicles:
Old 10-16-2015, 09:02 PM   #6
That01Olds
That01Olds's Avatar
^ No problem!
Old 10-17-2015, 08:17 AM   #7
kbubb91
kbubb91 is on a distinguished road
if hes going to replace the line anyways, cutting hose and pipe seems silly.
i had a leak on the grand prix, i literally sprayed "flex seal" on my gas-line. it worked perfect as a bandaid until the new hose came in
Gotta love the 2 door coup.
kbubb91 is offline   Reply With Quote
Old 11-25-2015, 12:20 AM   #8
turboalero
turboalero is on a distinguished road
Jus did both of mine. Move the fuse box. And make sure you buy a fuel line remover kit from your local auto parts store
turboalero is offline   Reply With Quote
Old 12-06-2015, 07:54 PM   #9
LD9 Alero
LD9 Alero's Avatar
I just got the hose and o rings, already have a quick disconnect tool. Any tips on how to remove the fuse box?
Edit: Never mind I figured it out.
My Vehicles:
Old 12-10-2015, 12:44 AM   #10
LD9 Alero
LD9 Alero's Avatar
Finally got the feed line changed out, the feed line is part #24576680 and the two o-rings are #12339317.
Also if you haven't already, you should probably check the condition of your Map sensor hose, it caused a misfire and I found the hose just sitting there rotted off on both sides.
A new one is part # gm6148-m
After doing some math, I found it's got 71K miles on NGK G-power single plats I put in, in 2007, still running ok, but probably time to change em out.
My Vehicles:
